Does This Contain Asbestos? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 04:47 PM   #1
Rewards Points: 184
Does this contain asbestos?
Does this contain asbestos? The markings say D VB 3/4x1/2 and the house was built in the early 60's. TIA
abefroman is offline   Reply With Quote
Old 01-12-2012, 05:20 PM   #2
Rewards Points: 6,652
How could it, since it is just a fiberglass insulation wrap.
Old 01-12-2012, 05:21 PM   #3
iminaquagmire's Avatar
Rewards Points: 338
That looks like fiberglass pipe wrap to me but nobody can give you a yes or no based on a picture. Have it tested if you're worried about it.
iminaquagmire is offline   Reply With Quote
Old 01-12-2012, 05:30 PM   #4
Fiberglass wrap is not going to have any bit of Asbestos in it. Now, it can contain Borax as a fireproofing material on the outer wrap, but it is far from containing any trace amount of Asbestos in it.
Old 01-12-2012, 05:37 PM   #5
Rewards Points: 184
Thanks, so is it safe to remove with a regular dust mask?
Old 01-12-2012, 05:55 PM   #6
Why do you want to remove it? It is there to insulate the pipe, either due to it is hot water for a boiler, or hot water from the water heater. Just leave and fix. Better than the foam wrap. Now, if it is saturated due to water leaking, yes you can just pull down and place into a plastic bag. Wear long sleeves, eye shield glasses, and a mask if you wish.
The Following User Says Thank You to gregzoll For This Useful Post:
abefroman (01-12-2012)
Old 01-13-2012, 04:56 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Yup. Seen pipe wrap around fiberglass insulation that was impregnated with asbestos. Also seen asbestos in the brush-on coating that was applied over fiberglass pipe wrap.
Old 01-13-2012, 05:21 PM   #8
It would have been the really old stuff. This stuff looks no older than maybe 20 to 30 years max, so it would not have it in it.
Old 01-13-2012, 05:33 PM   #9
Rewards Points: 184
I think you're right, that's a copper pipe which isn't original to the house, so the pipe, and insulation I'm assuming, would have been replaced at some point.
Old 01-13-2012, 08:38 PM   #10
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 864
+1
You can have asbestos in some of the older FG wraps in the mastic and other places but this does not appear old enough.
That being said, take PPE precautions regardless. Fiberglass is bad crap for your lungs as well.
vinyl siding over asbestos?? Buckeyes97 Remodeling 12 08-21-2012 10:20 PM
Can someone help me identify if these wall sidings are ASBESTOS? LynniieRockz Safety 15 12-01-2011 11:33 PM
Asbestos Siding - Bury or Remove Rock8Reno Building & Construction 17 10-24-2011 09:48 PM
Botched Asbestos Removal Several Years Ago...Remediation? vs1988 General DIY Discussions 10 08-17-2010 12:28 AM
asbestos & paint--let's talk. jaes Painting 4 08-10-2008 11:49 AM
