-   Insulation (http://www.diychatroom.com/f103/)
-   -   Does this change my insulation plans? (http://www.diychatroom.com/f103/does-change-my-insulation-plans-171045/)
ryanmcl 02-04-2013 08:17 PM
My foundation is covered with this waterproofing wrap.
http://www.deltams.ca/deltams_deltams.htm
Does this change any of the normal insulation procedures for the basement? 2" XPS, taped, caulked, ect ect.
Or is this more or less a safe guard to try and keep water away?
Ameri-Dry Guy 02-21-2013 11:12 AM
No if your foundation is waterproofed you should be able to install your insulation per manufacturers specs.
-Ameri-Dry Guy
Gary in WA 02-24-2013 06:32 PM
That product takes care of the moisture coming through the concrete wall. You could still get foundation to wall moisture wicking. Fig. 8: http://www.buildingscience.com/docum...ts?full_view=1
Also keep in mind foamboard on the cold concrete wall (air-sealed) prevents condensation from moist interior air, causing mildew/mold to susceptible wood frame walls, drywall paper, etc. The whole idea of foam is to raise the dew-point, preventing condensation in the cavity, compare f.g. wall with f.b. + f.g. wall in the Index here: http://www.buildingscience.com/docum...study-analysis
Gary
