Does This Ceiling Need More Insulation Before I Finish It? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-02-2014, 07:50 PM   #1
Does this ceiling need more insulation before I finish it?
I'm starting the process of finishing my basement, and I'm no handyman but the existing insulation looks a bit sparse and well-worn.
Before finishing the ceiling (which I would like to have can-lights) should I add some more insulation? The basement will be regularly used as an office so I want it to be comfortable and quiet, without the heat escaping in the winter.
Thank you in advance for any insight!
diytrying is offline   Reply With Quote
Old 03-02-2014, 08:00 PM   #2
Rewards Points: 13,446
Only reason any insulation is needed now that's it's being finished is for sound deadening.
It's going to be even less noisey once the 5/8 sheetrock goes up.
diytrying (03-02-2014)
Old 03-02-2014, 08:04 PM   #3
I see! Thank you very much for your answer. In that case, I will probably hold off on spending a few hundred dollars on insulation if it is not needed.
Old 03-04-2014, 10:31 AM   #4
Rewards Points: 186
Before you put up the sheet rock, look to the rim joist at the edges of the house, you would be better off sealing the edges of the house to keep any leaks out. Basically the insulation directly below the floor isn't going to do any good except transmit the cold air leaking in from the sides of the house.
http://www.familyhandyman.com/baseme...oists/view-all
Ocelaris is offline   Reply With Quote
The Following User Says Thank You to Ocelaris For This Useful Post:
diytrying (03-04-2014)
Old 03-04-2014, 04:51 PM   #5
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,020
Seal up the rim joist prior to sheet rocking it out.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 03-04-2014, 09:09 PM   #6
I wish I could "Thanks!" you twice! This is a great tutorial and we actually had a ton of spiders before a home energy audit where they sprayed expanding foam around the perimeter of the basement. It seems the spider problem is taken care of but I will definitely take your advice and seal off the rim joists. The basement is very cold and I want to make sure it's comfortable when I'm using it as a work space.
Old 03-04-2014, 09:10 PM   #7
Originally Posted by Windows on Wash View Post
+1
Thank you for weighing in! I took a look at that tutorial link and it does seem like a great idea, with good results at a low cost in money and time.
Old 03-04-2014, 10:18 PM   #8
Registered User
Rewards Points: 5,466
No need to go off-site from here; use our forum links (found at bottom of page or use "search" box at top page) for the answers; eg. Rim Joist insulation options?
How to insulate rim joists simply
Gary
Old 03-05-2014, 06:07 PM   #9
Rewards Points: 186
Thanks Gary, didn't mean to point people off site, in as much as I need a quick visual for people to get what rim joist insulation meant. I will sometimes check visuals from other sites but always come back here for solutions and real world experience.
I tried doing this to a few bays and the biggest problem I have is that my spray foam gun doesn't work very well "aiming up" i.e. it shoots air instead of foam, so I have a hard time filling the edges around the foam.
Gary in WA (03-05-2014)
Old 03-29-2014, 03:28 PM   #10
I am just now getting around to insulating the rim joints. I have read the tutorials linked in this thread but have a quick question for any of you insulation experts:
Currently, there is some fiberglass insulation on the inside of the rim joist. I take it that my best course of action is to:
  1. Remove the fiberglass insulation, caulk the openings behind it, and put it back
  2. Cut 2" insulation (preferably the kind with the foil on it) to size and place it on top of the fiberglass insulation
  3. Caulk the remaining openings
However, based on Gary's post in another thread I don't know if this will lead to condensation issues. Should I remove the fiberglass insulation entirely? I do plan on installing drywall, finishing this basement, and using it as a living space regularly.
Any expert advice would be much appreciated!
Old 03-31-2014, 10:45 AM   #11
Rewards Points: 186
If you're making a complete seal of the rim joist, i.e. like this thread:
The foam keeps the cold and hot separated so there isn't an issue with the condensation. I'm not sure what you mean fiberglass on the inside of the rim joist, do you mean up against the floor and happens to run into the rim joist? I would pull that back, totally air seal the rim joist and put the fiberglass insulation back.
The idea is to just not let any air from one side of the rim joist touch the other side... I'm about to embark on a similar project, and basically I use the foam as an air seal, and will be covering any wood on the cold side to keep it from getting through to the house. I'm not sure what benefit foil does after >1" of foam whether it's polyisocyanate or Expanded Polystyrene... I thought hit would be a vapor barrier as well as long as it's sealed.
The impression I got with fiberglass insulation is that it's fine as long as you air seal, but should never be relied on to stop air infiltration. So I would remove it as your purpose of sealing the rim joist is 90% for air sealing purposes, and fiberglass doesn't seal air very well.
diytrying (03-31-2014)
Old 03-31-2014, 04:28 PM   #12
Ocelaris, thanks for your advice! I think what I will do based on what you suggested and what I've read since my post is:
1. Remove the fiberglass stuffed in the rim joist presently
2. Caulk anywhere on the rim joist that air could move through
3. Cut a piece of 2" foiled rigid foam board insulation to size
4. Construction adhesive the rigid foam board into the rim joist
5. Caulk anywhere on the rigid foam board that air could move through
6. Put the fiberglass back over the rigid foam board
7. Proceed with framing and drywall
This way, the foam is between the warm interior / cold exterior and foil side in should prevent condensation (if the insulation itself doesn't). Also, the fiberglass is in an enclosed space (between the airtight rigid foam board and the drywall) which I understand is how it is supposed to work best.
I'm starting this little project within the next week as I wait for my permit to go through - I'll let you know how it goes! Thank you
Existing Cathedral Ceiling Insulation Question Bob Deb Building & Construction 8 12-07-2010 07:54 PM
Ceiling boxes and insulation WillK Electrical 1 11-08-2010 12:12 PM
Adding insulation to the underside of a high ceiling churchlady Building & Construction 6 11-17-2009 07:02 PM
wet attic insulation and ceiling drywall rojas66 Drywall & Plaster 4 03-04-2009 03:33 PM
ceiling insulation question christy123 Roofing/Siding 15 12-18-2008 12:22 AM
