Do I Really Need R50 Insulation In Garage Attic? - Insulation - DIY Chatroom Home Improvement Forum
Old 04-25-2014, 09:23 AM   #1
Rewards Points: 33
Question
Do I really need r50 insulation in garage attic?
Hi!
TD;DR: Would r20 or 30 be ok for my garage attic to help avoid condensation (and mold/mildew growth) on my ceiling drywall?
I have a house that's almost 2 years old.
The attached garage has the master bedroom above about 2/3 of the garage. The rest is garage attic that is uninsulated. All walls are drywalled, insulated, VP of course while the ceiling is drywalled and VP with no insulation in the attic. I have a mild/mildew on some ceiling drywall on the uninsulated part. I understand this is because it gets humid in there as the snow melts off the cars (central Saskatchewan) and the warm/moist air goes up and meets the cold drywall of the ceiling and cools which then condenses on the drywall and mild/mildew grows.
I'm going to blow in insulation and all the attic information I read says to use r50 (18.5 inches) but this isn't the house portion, just the garage. I'm thinking half of that perhaps? Just enough to keep the drywall from getting really cold in the winter.
recklessrick is offline   Reply With Quote
Old 04-25-2014, 10:08 AM   #2
Rewards Points: 33
One more thing, couldn't I just use batts of insulation? It's not a big area, only about 275 sq feet.
Old 04-25-2014, 01:24 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Is the roof vented?
Batts are fine.
Old 04-25-2014, 01:27 PM   #4
Rewards Points: 33
Originally Posted by Windows on Wash View Post
Is the roof vented?
Batts are fine.
Yes, the space is well vented through vents in the roof and soffits all around. I was just up there this morning checking things out. Batts would be easier because it's a smaller space and access to everywhere I need is not an issue.
Old 04-25-2014, 04:48 PM   #5
Cover the batt if you can with some housewrap to prevent wind washing and R-Value degrading.
Seal up the plates or around lights to keep the big moisture from getting up there.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Gary in WA (04-26-2014)
Old 04-25-2014, 05:06 PM   #6
Rewards Points: 33
Right on, easy enough to do.
Old 04-25-2014, 05:43 PM   #7
Rewards Points: 40
rick were you concerned with moisture in the garage space? Everything mentioned so far needs to be done, but this will only prevent moisture in the attic space not the garage space.
daveb1 is offline   Reply With Quote
Old 04-25-2014, 06:07 PM   #8
Rewards Points: 33
Oh yes, I plan on watching the moisture in the garage as well. I will be moving the water out as it melts from now on. Taking some more precautions to keep moisture out. Worst case, I'll need to put and exhaust and intake fan system.
Old 04-25-2014, 11:34 PM   #9
Rewards Points: 40
Sounds like you've got it under control. Good luck. And Go Riders!!!!
Old 04-26-2014, 06:03 AM   #10
True but it will also keep it on the warm side of the assembly. If the moisture gets into the attic and reaches cold surfaces, more likely to have condensation but I completely agree with you.
Old 04-26-2014, 08:38 AM   #11
Rewards Points: 33
Old 04-27-2014, 07:45 PM   #12
Registered User
Rewards Points: 526
You are basically; bringing inside an outside water/moisture source, Photo 7; http://www.buildingscience.com/docum...n-crawlspaces/ Cover with fire-code drywall on sleepers, keep it air-tight; http://www.buildingscience.com/docum...wall-approach/
Gary
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Attic insulation suggestions? iwfur25 Insulation 1 07-09-2012 11:50 AM
Insulation in the attic when the furnace is up there Jimmybrp Insulation 2 12-11-2011 02:26 PM
Attic Insulation tim1218 Insulation 4 09-07-2011 10:18 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
