DIY Spray Foam - Insulation - DIY Chatroom Home Improvement Forum
Old 01-10-2013, 08:14 PM   #1
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
DIY Spray foam
I'm considering spray foaming the underside of the roof of my 24x28 garage/workshop.
It's a trussed roof and the floor is plywooded and used for storage otherwise, I would batt insulate it.
Have any of you spray foamed something like this?
Pros? Cons?
tcleve4911 is offline   Reply With Quote
Old 01-10-2013, 08:19 PM   #2
Rewards Points: 13,458
One job I would hire out.
Ever seen it done by a pro before?
There going to have all the proper equipment and get this done in less then a day.
It's one nasty messy job.
Old 01-10-2013, 09:15 PM   #3
Registered User
Rewards Points: 5,492
Tips: http://www.energyvanguard.com/blog-b...oam-Insulation
Gary
Old 01-10-2013, 09:27 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Hey TC, where ya been?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 01-10-2013, 09:28 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Not sure. Usually when this is done. They install the ventilation shoots in-between the rafters before foaming. You said trusses. So i'm not sure.
747 is offline   Reply With Quote
Old 01-11-2013, 08:14 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,164
Don't bother to try it on that large a size.
It will cost you more money and not come out well.
The Following User Says Thank You to Windows on Wash For This Useful Post:
tcleve4911 (03-10-2013)
Old 03-10-2013, 10:03 PM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Hey Jim,
I had some health issues and needed to lay low for a bit.
I've been over in the WWT turning section.
I got a new lathe but the old one's still being used with the banjo you gave me.
Good to see ya !!!!
Tom
Old 03-10-2013, 10:48 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
Originally Posted by tcleve4911 View Post
Hey Jim,
Good to see ya !!!!
Tom
I see you on WWT all the time, I hope you are doing better now days buddy.
Jim
Spray foam in attic diystephen HVAC 6 12-29-2012 01:07 PM
Does closed cell spray foam justify it's cost in an attic? ls3c6 Insulation 1 01-09-2012 07:41 AM
DIY spray foam ACR_SCOUT Insulation 12 12-30-2011 06:57 AM
spray foam newmanab Building & Construction 1 03-25-2010 03:45 PM
Closed Cell Spray Foam insulation and hiring a contractor. Spud Building & Construction 2 10-14-2009 09:03 AM
