DIY Foam Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 01:06 PM   #1
DIY Foam Insulation
Has anyone ever tried doing their own foam insulation? They do sell kits for homeowners, a little expensive. One brand is Tiger Foam.
Smoke is offline   Reply With Quote
Old 03-10-2012, 03:18 PM   #2
Rewards Points: 660
Look on You Tube, there are a million videos.
What are you looking to do? For my rim joists, i just cut pieces ox XPS to size and caulked the edges and used Great Stuff on top of that. More time consuming but less expensive.
B
Beepster is offline   Reply With Quote
Old 03-10-2012, 03:29 PM   #3
concretemasonry's Avatar
Rewards Points: 2,594
Beepster -
I did the same system, but opposite and cut the 2" XPS roughly close (a little small), applied the foam around the rim /joist cavity and quickly shoved the XPS in and let the foam seal and glue it in place. It has performed well. - I hate to cut precisely, when foam can make up for the variations.
Dicl
concretemasonry is online now   Reply With Quote
Old 03-10-2012, 05:52 PM   #4
Registered User
Rewards Points: 5,482
Beepster, good job. Double protection for when the foam air seal breaks- even 1/16", the caulking (and backer rod = A+) will still stop air, as it moves with the solid wood. Canned foam can take no movement...
Engineered wood- no worries, it won't expand and contract from the changing seasons- from 6-12% R.H. = 3/8 to 1/2" depending on the rim width: http://www.buildingscience.com/docum...d-but-strange/
Page 51: http://books.google.com/books?id=iwS...rafter&f=false
Gary
Old 03-16-2012, 02:28 PM   #5
B
I've thought about doing this between the rafters in my unvented attic. Any idea how well this would work?
rion.martin is offline   Reply With Quote
Old 03-16-2012, 04:10 PM   #6
Too Short? Cut it Again!
Just a sort of anti-DIY comment I guess. I have found having the pro foam spray guys do the job so much cheaper. Of course it is near impossible to get them out for a little job but I have found if you can be schedule flexible they can be very cooperative.
Spray foam insulation odor Ranger1227 Insulation 6 02-14-2012 11:53 AM
Hybrid Spray/Rigid Foam Insulation yaemish Insulation 4 01-20-2012 11:55 PM
Canned Foam Insulation WindingRoad Building & Construction 5 01-02-2011 09:08 AM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 10:44 PM
Foam Insulation turbomangt Roofing/Siding 13 11-02-2010 09:44 PM
