Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 04-08-2012, 12:42 PM   #1
Dispensing straws for canned expanding foam
Does anyone know of someplace where you can get additional dispenser straws? I have two cans of the stuff but no straws haha.
Michaelpro is offline   Reply With Quote
Old 04-08-2012, 01:35 PM   #2
no, but if in the future you want to clean a used nozzle, use acetone and hit it right away. then, reuse the nozzle. i suppose you could buy a new can and keep using the one nozzle????? or, snap one off a can on the shelf. kidding.
The Following User Says Thank You to jklingel For This Useful Post:
Michaelpro (04-09-2012)
Old 04-08-2012, 03:06 PM   #3
I uses a pen with the ends removed. Worked well enough!
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
Old 04-08-2012, 03:21 PM   #4
the Musigician
DangerMouse's Avatar
Find a job that needs 3 cans, buy one can, then reuse the straw. If you allow it to harden inside the tube, a drill bit or screw will remove the dried plugs and you can put it in a drawer in case it ever happens again.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
Old 04-08-2012, 06:09 PM   #5
Go to plumbing with a can and find the tubing that fits it. I did this and found 10 ft of tubing that fit the nozzle perfectly for $3 or so and cut off a bit every time I need to use the can. Also good because you can stick the tubing up a void and full as you pull it out. Just be careful if you do this of the pressure from expansion.
MLMIB is offline   Reply With Quote
The Following User Says Thank You to MLMIB For This Useful Post:
Old 04-08-2012, 09:11 PM   #6
Learning Things Every Day
Jay 78's Avatar
McDonalds, or your kitchen.
If you're talking about cans like Great Stuff, the top of the can that the straw attaches to is threaded, meaning you can twist on any type of straw with an appropriate diameter.
I use the straws out of the hundred-pack I bought at the grocery store, which actually has the dimensions on the box: 7.625" long, .25" diameter. They're what I consider 'standard size' straws.
Under Construction
Jay 78 is offline   Reply With Quote
The Following User Says Thank You to Jay 78 For This Useful Post:
dogris (04-09-2012)
Old 04-09-2012, 03:16 PM   #7
If I don't use a whole can at once, I thread a drywall screw into the top of the straw. This usually " seals it pretty good. Take out the screw next time and foam away.
alecmcmahon is offline   Reply With Quote
The Following User Says Thank You to alecmcmahon For This Useful Post:
chemman (04-24-2012)
Old 04-09-2012, 03:46 PM   #8
This is a fantastic idea. Thanks!
Old 04-09-2012, 03:47 PM   #9
Using this with the straw idea will work great I think. Thanks!
Old 04-25-2012, 02:35 AM   #10
Every time I use a regular straw the pressure from the foam pushes the straw off causing a horrible mess
Jman26063 is offline   Reply With Quote
The Following User Says Thank You to Jman26063 For This Useful Post:
Tom Struble (04-25-2012)
Old 04-25-2012, 02:52 AM   #11
Exterior Construction
Windows on Wash's Avatar
The poly tubing in the plumbing aisle of the big box stores work just fine.
Check there.
Old 04-25-2012, 07:21 AM   #12
Jay 78's Avatar
I don't have that problem. What I do to get it started is push down on the base of the nozzle with both thumbs - half of a thumb on the straw, the other half on the base of the can. Once it starts flowing through most of the straw, the pressure is low enough where it won't blow the straw off. This has been my experience with the cans that I've used that have come with pre-broken straws.
FWIW, I'm not saying there's no better alternatives, but I mentioned this because straws are something people are likely to already have on-hand.
Under Construction
Old 04-25-2012, 12:24 PM   #13
I returned my can that was missing a straw and they exchanged it for a new one at HD.
Are you saying if you put a screw in the straw the foam doesn't dry/cure? Seems like it would harden up pretty quickly, but maybe without air it would work.
mikegp is offline   Reply With Quote
Old 04-25-2012, 12:32 PM   #14
Tom Struble's Avatar
jury rigging one of those inside a house is scarey
Tom Struble is offline   Reply With Quote
Old 04-25-2012, 06:22 PM   #15
If you thread the screw in about 5-6 threads, the stuff in the tip of the straw cures, but the rest reverts to a liquid form. The screw comes out pretty easily taking the cured foam with it. Works great!
chemman is offline   Reply With Quote
expanding foam vs cutting sheets of rigid foam for rim joists Red Squirrel Building & Construction 15 11-24-2010 12:46 AM
Expanding Foam and Radiators limbodog HVAC 1 11-01-2010 05:07 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
cleaning out expanding foam nozzles anervoustwitch Tools 7 08-10-2009 07:30 AM
expanding foam flamability BigDogg77 Building & Construction 11 12-03-2008 11:48 AM
