Detached Garage Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 10:29 AM   #1
Rewards Points: 320
I am thinking of insulating my detached garage. I will occasionally be heating it with a portable heater when I work out there on the coldest days of the winter. I may put in a small a/c unit in the future. The walls will not be finished except for perhaps peg board on a couple of the walls. I was thinking of using fiberglass batt type. Should I use un-faced with a plastic vapor barrier or paper lined batts? Any other types that I should consider?
teamo is offline   Reply With Quote
Old 10-25-2013, 10:48 PM   #2
Registered User
Rewards Points: 4,920
Insulation with a poly vb will have moisture from inside condense on the poly without an air barrier (eg. drywall). I would not think of leaving fg uncovered, examine the bottom of the wrapper/bag it comes in- carefully... Other- depends on how much money to spend, lol.
Gary
Old 10-26-2013, 06:41 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
Do not use plastic skrimmed.
The plastic facing would therefore make it faced FYI.
I would use standard Kraft faced batts if you are going to use Fiberglass.
Old 10-26-2013, 11:40 AM   #4
Rewards Points: 320
I will need to insulate all the way to ridge since there is no dry wall going on the ceiling and there is no framing for a ceiling on half of the garage (the other half is a loft/storage space. I have a full ridge vent and also vented vinyl soffits. I will need to use foam baffles from the soffit space all the way to the ridge correct? It doesn't seem like those foam baffles provide much stand off/air space from the under side of the roof. Is this enough air circulation?
Old 10-27-2013, 01:05 PM   #5
Registered User
The foam ones tend to rip on the exposed fasteners sticking through the roof sheathing, and they are only 18.7 NFVA. The plastic ones from the same store (HD) are much better, maximizing airflow at 25.3 and they don't burn; http://www.adoproducts.com/as_durovent
http://www.bergerbp.com/products_ven...n_accuvent.php
Yes, to ridge- unless open attic above the ceiling line; where the rafter ties are located, overlap the lower for drainage out the soffit for condensation moisture as per manufacturer. Vent every bay. Drywall against moisture rotting the framing.
Gary
Detached garage insulation n0c7 Insulation 9 03-04-2013 11:38 PM
Electrical in detached garage mattjub Electrical 6 04-07-2010 11:44 AM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 01:08 PM
Detached Garage Insulation Unregistered Building & Construction 2 02-28-2004 04:31 PM
