Dense Pack Cellulose Hose Reduction? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-25-2013, 03:36 PM   #1
dense pack cellulose hose reduction?
Im going to be doing some wall dense pack cellulose insulation with the Krendl 425 blower from menards does anyone have any tips for me and is it really nessary to reduce the hose size from 2 1/2" to 1 1/2 ". i have a balloon construction style home and have easy access to wall cavitys without the need to reduce the hose size so my question is it a air pressure thing thats why you need to reduce the hose??? or can i just use the standard 2 1/2" hose that comes with the machine???
Marty
Does anyone have any expertise on this subject??
Ive posted two questions and absolutly no one has any input on either subject
feeling kind of let down, i figured some would have some knowlege on this.
Marty Tappe is offline   Reply With Quote
Old 02-26-2013, 11:45 PM   #2
Registered User
Rewards Points: 5,212
I don't insulate for a living but I will send a PM to someone who does, another member. Meanwhile here is some general reading for you, from my library; http://www.greenbuildingadvisor.com/...ose-insulation
http://www.karg.com/pdf/Presentation...Insulation.pdf
http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Marty Tappe (02-27-2013)
Old 02-27-2013, 10:43 AM   #3
Thanks gary for all the much needed info
The Following User Says Thank You to Marty Tappe For This Useful Post:
Gary in WA (02-27-2013)
Old 02-27-2013, 12:50 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sorry for the delay...
You can dense pack with a Menards krendl, but you have to make sure it isn't missing the feed gate and make sure that it comes with a remote that works. This is critical because if open at full feed you will dense pack the hose and not the wall cavity. You must use a 1.5" ID hose, not from Menards, theirs come pre-kinked and will clog, go to Home Depot theirs come on a big roll and cut to size. Normally you would get a 10' hose, however you will want to get 16' if you are trying to dense pack a 2 story balloon frame home. You want to get the hose down as far as possible. It is necessary to reduce down to the smaller size to actually get a proper dense pack, however you can fill the cavities with the 2.5" hose first so that the dense packing will go faster. The 2.5" alone will not get the proper density. Menards may or may not rent the reducer for the smaller hose, but one can be purchased from an insulation supply place. For more information go to the Krendl website, they have how to videos on YouTube.
Hope that helps!
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
The Following User Says Thank You to HomeSealed For This Useful Post:
Old 02-27-2013, 01:34 PM   #5
Thanks again for all the info on the subject, im going out to menards tonight to see just what type of hoses come with rental machine if they dont have the reducers from 2.1/2" to 2" and then to 1.5" i will buy them from a place online
called J&R Products. I talked to a person named Dan and he said i needed to run 50 foot of 2.5" hose and reduce to 2" for 50 feet and then reduce down to 1.5" Wall tubing about 10-15 feet long. Does that sound about right?
Old 02-27-2013, 04:29 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
You dont need the 50 feet of 2", that's how I was originally taught and it works, but not necessary. Hoses are usually sold in 50 foot sections. We run our machine with 100 feet of 3" and then 1 ft of 2" then down to the 1.5" and that doesn't have any problems at all. However you do need to reduce down to the 2" hose, so 50 feet is what you may have to use. Either way you will need at least 100 feet of hose plus the 10-15 feet of dense pack tube.... That's probably more info than you need, so to answer your question, YES, the way he explained it will work.
www.HomeSealed.com
Old 02-27-2013, 06:02 PM   #7
Thanks to both of you for all your help, now i have a good base of information to get thru this. wish i lived close enough to buy you both a beer.
Thanks Again
Marty
Old 03-11-2013, 10:02 AM   #8
Tried to dense pack
Tried to dense pack cellulose in my walls this past weekend. Either i was doing something wrong or the Krendle 425 blower was not powerful enough? it kept getting cloged at the 2" to 1.5" hose reduction point, but if machine had more blower power i think that it would not have cloged at that point and in turn would have dense packed the cavity. you could not even tried to bogg down the machine in any way without the hose being clogged.
Going to plan B whatever that is??
F.G. or cellulose Nailbags Insulation 13 02-16-2013 04:12 PM
DIY Dense Packing Cellulose? dalesizemo Insulation 2 09-17-2012 06:40 PM
Dense pack cellulose against fiberglass shower stall crankcase Insulation 1 02-08-2012 12:33 PM
Netting selection for dense pack cellulose crankcase Insulation 3 09-10-2011 08:41 AM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
