Is Dark Gray Attic Insulation Ok? Is It Worth Replacing With Batt Insulation? - Insulation - DIY Chatroom Home Improvement Forum
Old 11-22-2011, 12:06 AM   #1
Is dark gray attic insulation ok? Is it worth replacing with batt insulation?
I bought a house near Seattle, constructed in the 1970s.
The insulation in the attic is a dark gray loose fill. Is this color ok?
Also, I measure, it's only about 5 inches deep, which ... but it is covering the floor joists.
Ugh seems really dirty and messy though. Is it worth it to clean my attic out of this gray loose insulation and replace it with neater pink Batt Insulation?
entropyjx is offline   Reply With Quote
Old 11-22-2011, 07:16 AM   #2
DIY staff
Rewards Points: 7,174
That's blown in cellulose ---perfectly fine insulation---I suggest you add more as 5" is not enough for r-38 ----
Old 11-22-2011, 09:16 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,860
+1
Not even close. You really should shoot for an R-50 at that.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oh'mike (11-22-2011)
Old 11-22-2011, 07:07 PM   #4
If I put another 5 inches, it'll be really high and might poor out of the attic entrance?
Is Batt better or worse insulation? I really like how it's so neat and not loose.
Old 11-22-2011, 08:28 PM   #5
DIY staff
Make a plywood collar if you want to---
Old 11-23-2011, 12:08 AM   #6
+1
Make a wall around the scuttle of plwood, cardboard, or rigid foam. Pretty much anything will work but the woods will be more structural if you are leaning on them much to get up there.
Old 11-23-2011, 12:13 AM   #7
liscenced electrician
Rewards Points: 538
Or even 1 batt of r30 or 38
jimmy21 is offline   Reply With Quote
Old 11-23-2011, 01:30 AM   #8
Registered User
Rewards Points: 5,216
A belated "Welcome to the forums!" to a neighbor just North of me.
WA State has it's own "Energy Code" -a little tougher than IRC. Page #55, here: http://www.energy.wsu.edu/Documents/...ers%201-10.pdf R-49 is minimum, the guys here are "right-on"!
Air seal by raking the existing out of the way, to reuse. http://www.google.com/url?sa=t&sourc...O842EQ&cad=rja
Gary
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Attic Project – Venting and Insulation spaceboy Insulation 3 09-08-2011 10:54 AM
Putting up additional insulation in the attic Rafalski Insulation 10 04-16-2011 11:58 PM
Attic Foam Board Insulation JasonCA Roofing/Siding 3 10-07-2010 01:56 AM
Attic insulation Hammiamm Roofing/Siding 5 12-02-2008 03:39 PM
