Crawlspace Walls - Insulation - Page 5 - DIY Chatroom Home Improvement Forum
Old 01-23-2012, 06:50 PM   #61
Rewards Points: 280
Originally Posted by GBR in WA View Post
The plastic alone is fine on the walls unless it is a conditioned crawlspace. You want conditioned if the HVAC ducts are down there. To condition---- insulate the walls, otherwise, insulate the floor. I would mastic or asphalt emulsion the plastic as it has to be air tight. You will still have problems with the joists getting wet from any other moisture source under there, along with radiation because the walls are not insulated, only plastic covered, leaving a cold crawlspace:
Gary
But is it wise to do both? Cover the walls with plastic, then put rigid foam board on top of the plastic.
If yes, why couldn't I just use something like Dow's Thermax which is a glass-fiber-reinforced polyisocyanurate insulation board with a foil covering? Foil for the air seal and the core for insulation.
That is the question I have been trying to get answered.
Update: I found this at Dow. http://msdssearch.dow.com/PublishedL...romPage=GetDoc
Earnie is offline   Reply With Quote
Old 01-23-2012, 09:51 PM   #62
Registered User
Rewards Points: 526
Sorry, I guess I made it confusing to understand.
NO plastic if using foamboard.
Tape to joints with foil tape. Check with local AHJ for air exchanges.
Gary
Old 01-24-2012, 09:31 AM   #63
AGWhitehouse's Avatar
Originally Posted by Earnie View Post
AGW,
From your experience and educational background, do you advocate installing polyethylene film (6 mil plastic) from ground level all the up (in my case to within 3 inches of the rim joist) block crawlspace walls?
Also, if insulating a block crawlspace wall, would you specify extruded polystyrene (XPS) rigid foam board or foil faced polyisocyanurate foam board?
I understand local code is the final word but just interested in your point of view.
I'd recommend either the plastic or the XPS foam, depending on your budget. There is no need to use both.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 01-24-2012, 11:06 AM   #64
Rewards Points: 280
Thank you for the reply Gary and AG.
Old 01-24-2012, 02:14 PM   #65
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,258
What...I get no love
The Following User Says Thank You to Windows on Wash For This Useful Post:
AGWhitehouse (01-24-2012)
Old 01-24-2012, 10:35 PM   #66
Registered User
Rewards Points: 526
Well, I've been home sick for 3 days, and I answered one right, and got a thanks! I'm feeling pretty good, I'll give you one of mine; take your right hand, reach over the left shoulder........
I'm staying out of the staff break room, think I picked up a virus there...
Gary
PS- For WW:
Old 01-25-2012, 09:19 AM   #67
Rewards Points: 280
Hey, I gave you one in post 50. But it I can make your day better ............
Thank you Wash for your helpful replies to my questions.
The Following User Says Thank You to Earnie For This Useful Post:
Windows on Wash (01-25-2012)
Old 01-25-2012, 04:33 PM   #68
I'll take it.
Ventilated or Unventilated Crawlspace? Thunder Chicken Building & Construction 12 01-09-2012 09:08 PM
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
Clean crawlspace cinderblock walls (prep for sealing)? syntax53 Building & Construction 1 07-20-2010 01:12 PM
Need to rebuild outside steps and walls coming from basement doug123 Building & Construction 31 05-03-2010 07:45 AM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
