Crawlspace Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 12-12-2011, 02:53 PM   #1
Rewards Points: 272
Question
If I was going to install a new vapor barrier on the floor of my crawlspace and I also wanted to install rigid foam board on the foundation wall for insulation, given the choice would I want to attach the vapor barrier directly to the foundation wall first then install the foam board over top? Or Should I install the foam board directly to the foundation wall and bring vapor barrier up past the foam board like attached photo?
Browsing online & youtube I've seen companies do it both ways, not sure if there is a gain one way or the other. I attached a pic of one companies recommendation. I also have a sill ledge (see attached photo) where I can come up that far and attach the barrier to that as well but not sure if there are any downfalls to that besides using more material. Thanks in advance!
cbaur88 is offline   Reply With Quote
Old 12-12-2011, 04:25 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,718
Seal the vapor barrier to the crawlspace wall. It is easier and and you don't want any of the moisture/earth smells moving inside gaps in the foam board if you don't get it sealed up perfectly.
The Following User Says Thank You to Windows on Wash For This Useful Post:
cbaur88 (12-14-2011)
Old 12-14-2011, 01:11 PM   #3
Rewards Points: 272
Thanks WW, what's the best way to attach the foam boards to the foundation wall? I'll try a sealant but the wall is not flush flat, allot of excess mortar sticking out which I guess I can chip away but just in case is there some type of nail,screw, sinker that will hold these babies up against the wall. Thanks a bunch once again!
Old 12-14-2011, 02:06 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Liquid nails or Eagle Grip.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
Old 12-15-2011, 09:23 PM   #5
Registered User
Rewards Points: 5,516
Additional work may be required if in a termite or radon zone; http://energy.cr.usgs.gov/radon/rnus.html
http://termites101.org/termite-basic...ites-by-region
You may need a p.t. plate holding the plastic to the concrete at exterior grade level with the top open for termite tunnel inspections.....
Gary
Old 12-16-2011, 07:45 AM   #6
Rewards Points: 272
Gary
Thanks for the info Gary but that's all greek to me. I think I understand what a P.T. plate is but not sure what you mean by it holding the plastic to the concrete. From what I've read the PT plate should be somewhere on the sill ledge and installed at construction. So far I see no signs of termites down there so that is good news. Perhaps a termite inspection and regular preventative maintenance will keep it that way going forward.
Old 12-17-2011, 09:31 PM   #7
Registered User
You may want the plastic to extend up the wall only 6" or so. The plastic is stopped from completely covering the wall to inspect the wall for termite tunnels. If not a concern, fully cover with insulation. Supply exhaust air if converting to a conditioned crawl...
Treat it as a basement wall, no plastic above-grade to condense water in Summer; http://www.buildingscience.com/docum...ce-insulation/
http://www.buildingscience.com/docum...ance-and-codes
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
cbaur88 (12-19-2011)
crawlspace slab voids, basement water geoffmiller Building & Construction 0 11-25-2011 09:01 AM
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 07:03 AM
getting the most out of a heated crawlspace Gerry Fossum HVAC 2 06-08-2011 07:42 PM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 01:35 PM
crawlspace exposed to outside and damp djbauda Building & Construction 5 07-30-2007 07:49 AM
