Crawlspace Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 12-05-2013, 04:37 PM   #1
Rewards Points: 41
I had a question about installing insulation under my house. Please excuse the horrible drawings.
I saw someone install foam board insulation before and they placed smaller strips to each side to create a gap(air pocket).
See picture.
Which way is correct?
01grander is offline   Reply With Quote
Old 12-06-2013, 12:23 AM   #2
Registered User
Rewards Points: 5,266
Optimal installation, may require ignition barrier, check with local AHJ; Fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Depends on what you want for the end result; http://www.buildingscience.com/docum...al-performance
Gary
Old 12-06-2013, 05:47 PM   #3
Rewards Points: 41
I can't really use fiberglass batts because of the moisture where my house is located. It would just attract mold too much. The picture I drew was just for foam board to add some insulation since I currently have none.
Which of those would work best? The foam board directly to the underside of the flooring or leaving a gap by placing a thin strip on either side?
Old 12-07-2013, 07:12 AM   #4
Rewards Points: 226
my understanding is that gaps are bad.
Fix'n it is online now   Reply With Quote
Conditioned Crawl Space Insulation LuckyFoot15 Insulation 4 09-30-2012 02:35 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 02:35 PM
crawlspace insulation under porch shtoink Building & Construction 8 11-12-2009 08:50 AM
