-   Insulation (http://www.diychatroom.com/f103/)
-   -   Crawlspace Insulation (http://www.diychatroom.com/f103/crawlspace-insulation-191525/)
01grander 12-05-2013 03:37 PM
1 Attachment(s)
I had a question about installing insulation under my house. Please excuse the horrible drawings.
I saw someone install foam board insulation before and they placed smaller strips to each side to create a gap(air pocket).
See picture.
Which way is correct?
Gary in WA 12-05-2013 11:23 PM
Optimal installation, may require ignition barrier, check with local AHJ; Fig.7; http://www.buildingscience.com/docum...n-crawlspaces/
Depends on what you want for the end result; http://www.buildingscience.com/docum...al-performance
Gary
01grander 12-06-2013 04:47 PM
I can't really use fiberglass batts because of the moisture where my house is located. It would just attract mold too much. The picture I drew was just for foam board to add some insulation since I currently have none.
Which of those would work best? The foam board directly to the underside of the flooring or leaving a gap by placing a thin strip on either side?
Fix'n it 12-07-2013 06:12 AM
my understanding is that gaps are bad.
