Crawlspace Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 11-30-2013, 05:37 PM   #1
Crawlspace insulation
Hi. Just have a general question. I have a vented crawlspace, live in San Diego and I want to insulated my floor from below. I can install roxul or fiberglass batts. Currently there is nothing there. Do I need a vapor barrier? If so, should I use kraft faced insulation? Vapor barrier on the ground? Any help is greatly appreciated. Thank you
wmcnulty is offline   Reply With Quote
Old 11-30-2013, 09:42 PM   #2
Dave Sal's Avatar
Rewards Points: 600
http://www.buildingscience.com/docum...=Crawl%20space
Click the above link and download the PDF file for info on crawl spaces, insulation and venting.
Dave Sal is offline   Reply With Quote
Conditioned Crawl Space Insulation LuckyFoot15 Insulation 4 09-30-2012 02:35 PM
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 02:54 PM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
Crawlspace Moisture - Serious Problem PaoloM General DIY Discussions 11 12-15-2009 02:35 PM
crawlspace insulation under porch shtoink Building & Construction 8 11-12-2009 08:50 AM
