Crawl Space Wall Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-04-2014, 08:42 PM   #1
RustyRealtor's Avatar
Rewards Points: 287
Hello,
I have sealed my crawl space (in Nashville), but I have yet to insulate the walls. And the reason is that I can't fit the rigid foam through the crawl space opening without having to cut it into narrow strips. Should I bite the bullet and cut the rigid foam, or should I use some other form of insulation (I can't afford spray foam).
Many Thanks,
Russell
RustyRealtor is offline   Reply With Quote
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
Crawl space and insulation.. valcarmo72 Building & Construction 8 02-23-2013 08:40 PM
Converting Vented Crawl Space to Unvented/Conditioned Achille76 Building & Construction 4 02-19-2013 09:10 PM
Vented crawl space insulation gregsenne Insulation 9 10-10-2012 02:56 PM
how to install roxul insulation in a crawl space ciling. plastic Insulation 5 12-18-2011 12:27 AM
