Crawl Space Vents Confusion - Insulation - DIY Chatroom Home Improvement Forum
Old 01-26-2012, 10:29 AM   #1
Rewards Points: 208
i have 3 vents in my crawl space that lead to the outside. i was told by one contractor that they should be sealed. i was told by another contractor that they should be left open with a grill and screen. what is the correct thing to do?
Scully is offline   Reply With Quote
Old 01-26-2012, 10:34 AM   #2
Rewards Points: 13,250
Unless you plan on making it a conditioned space leave it as is.
I'd remove the vents you have now and install automatic opening ones.
There about $17.00 each and take all of 10 min. to replace.
Then they will open when it's warm and close when it cold.
Any time I see a sealed unconditioned crawl space there's fungus on the floor joist and subflooring.
You do have 6 mil. plastic on the ground to act as a vaper barrier right?
Old 01-26-2012, 10:46 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,770
Read anyone of the myriad of threads on here about sealing crawlspaces.
Did the contractor that said to close them up and seal them recommend that along with other items or just that?
Did he say to do that just during the winter or as a general rule across the board?
If he said to do that permanently, run from that contractor.
Old 01-26-2012, 10:54 AM   #4
Rewards Points: 208
he said to install vapor barrier and permanently seal the vents in crawl space. this is what he quoted me for:
install 6 mil vapor barrier to ground in crawl space and drape up wall and secure to wall: $777.00
Air seal: foam 3 vents shut in crawl space in basement:$175.00
Old 01-26-2012, 11:26 AM   #5
Does he plan on insulating the crawlspace wall too?
You need to if you convert it to a conditioned/sealed crawl to do it right.
Old 01-26-2012, 01:05 PM   #6
All things any DIY could do for less then $100.00 or less in materails.
And a few hours time.
Inless someone also adds a way to heat and add A/C to this crawl and insulate the walls it's a waist of time and money to block up the vents.
Old 01-26-2012, 02:29 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 710
Okay, I'll fill in for Gary here: http://www.buildingscience.com/docum...ce-insulation/
That number quoted above is utterly ridiculous as is amount of time necessary to properly treat a crawlspace. Joe, what are you insulating/sealing the rimjoist with in your $100 quote for materials?
Scully, as WoW mentioned, if he is sealing the space (which IS recommended in most cases) the cs will need to be insulated (walls) and air-sealed as well. Pricing is subject to a bunch of factors, not the least of which is the size of your space. If that info that you copy and pasted is the entirety of the quote that you were given, you probably want to find a different contractor. His scope of work is incomplete, and his description is vague to the point of being unprofessional.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-28-2012, 07:10 PM   #8
While I'm a huge fan of sealed crawl spaces ... did he say WHY to seal the vents? Did he take moisture readings in the joists? Fungi? poor insulation or any other signs of high-humidity problems?
Fact is, if your crawl space is okay, you don't NEED to spend the money to seal and condition unless you're looking for the environmental and efficiency improvements.
I would avoid the automatic vents, though. The purpose of a vented crawl is to clear out the humidity in the crawl. Auto. vents are temperature sensitive and open or close regardless of how poor the humidity level may be in the crawl. On cool days you can have them closed and have amazing problems beneath the home. Better to be aware of what's going on beneath your home and open/close vents manually.
Finally, you didn't mention where your house was... that could help with the advice. or square footage of home. or size of crawl, conditon, etc.
CrawlSpaceMoist is offline   Reply With Quote
The Following User Says Thank You to CrawlSpaceMoist For This Useful Post:
HomeSealed (01-30-2012)
Crawl Space Questions mark2741 Building & Construction 1 12-24-2011 12:20 AM
Old Septic pipe flooding into crawl space ktipton Plumbing 2 04-14-2011 03:18 PM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 08:52 PM
Crawl Space Advice mjarema414 Building & Construction 0 02-04-2011 09:09 AM
Crawl Space Issues / Too Many Layers of Floor jdmindy71 Flooring 1 12-31-2010 06:09 PM
