Crawl Space Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 10-16-2012, 12:36 PM   #1
crawl space vapor barrier
House at the shore with a dirt crawl space what mil vapor barrier should I use? I have a musty smell coming from the crawl space.
dpiscitelli is offline   Reply With Quote
Old 10-16-2012, 12:56 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,732
It depends if you're gimme storing stuff in the crawlspace. If you're not to be story anything in the crawlspace then any minimum thickness plastic, usually 6 mil or better will work just fine.
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Is my crawl space considered non-vented?? Mr Blotto Insulation 3 07-18-2012 10:52 AM
Crawl Space cleitch Building & Construction 4 05-28-2012 10:57 PM
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 09:32 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
