Crawl Space Order Between Foam Insulation And Vapor Barrier - Insulation - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 04:37 PM   #1
Rewards Points: 39
Crawl Space Order between Foam Insulation and vapor Barrier
Only a small section of our house was built on a crawlspace, but it is cold and musty. I plan to install 2" Formular on the walls with a vapor barrier above the dirt floor.
Most sites say to continue the vapor barrier up the walls, but does the vapor barrier go between the wall and foam board or on top of the foam board?
KansasCity is offline   Reply With Quote
Old 01-09-2014, 09:09 PM   #2
Registered User
Rewards Points: 5,460
Depends if the foamboard on wall goes below outside grade or not- it should, at least to "frost depth"; http://www.google.com/url?sa=t&rct=j...59026428,d.cGU
https://www.decks.com/deckbuilding/D...rost_Depth_Map
http://energy.cr.usgs.gov/radon/rnus.html
Leave top 2" of FB off for termite inspect; http://termites101.org/termite-basic...ites-by-region
Gary
PS. be sure to ventilate the space...per code.
Old 01-10-2014, 07:46 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,990
Its easier to get a more complete seal if you seal the vapor barrier to the wall and not the foam.
Check code on the ability to leave exposed foams without ignition or thermal barriers.
Sounds like you are proposing to turn the crawl into a conditioned space so the venting suggestions might be moot.
Old 01-10-2014, 04:24 PM   #4
Registered User
"Sounds like you are proposing to turn the crawl into a conditioned space so the venting suggestions might be moot."------------------------------- you should really read the first link about ventilation I left..... lol.
Gary
Old 01-10-2014, 05:25 PM   #5
Gary
I have read it from before. We have the same bookmarks Gary but you have them down to a fine science and cataloged for quick disbursement.
My point being about the language used is that most DIY readers will recognize the language and understand the idea of conditioning better and will likely commingle the ventilation term with how an ventilated crawl is used.
I also disagree with the idea of venting a seal crawlspace in order to introduce conditioned air via air loss. Seems to defeat the purpose of sealing up for a tighter envelope.
If the insulation and vapor barrier on the floor are right, it takes minute amounts of conditioned air to affect the necessary change via supply side or transfer.
Old 01-10-2014, 07:58 PM   #6
Registered User
I think it is prudent to supply some air, enough to remove moisture present. Rather too much than too little as the consequences can be disastrous with mold/mildew/rot and health problems too boot. And you will always have moisture in a crawlspace, IMO. They are not tested for air pressure leakage or intake with a blower door, until that happens, there will be small sources for moisture. Just as many think they air-sealed the framing well; at the blower door test- they wake up from the dream....lol. The best system I've seen is waste air from living areas (after an HRV) going through a dehumidifier, then supply the crawl, and exhaust it to exterior from there.
My statements are to meet code minimum, hence the link and this discussion. Though it sounded like you were saying one doesn't need ventilation (per code) in a conditioned crawl... as "mute" to me means "silent" or no contribution.
Gary
PS. be sure to ventilate the space... with house air- per code. Fixed it...lol.
Old 01-11-2014, 06:48 AM   #7
Agreed 100%.
Have to have some communication and circulation.
Old 01-11-2014, 03:22 PM   #8
Rewards Points: 39
Thanks again for the links and information. I am going to take a few pictures tomorrow and confirm that I have understood everything correctly, before buying supplies.
The Following User Says Thank You to KansasCity For This Useful Post:
Gary in WA (01-11-2014)
Old 01-14-2014, 10:20 PM   #9
Dave Sal's Avatar
Rewards Points: 626
If you do this right (by following the links and suggestions provided) you will probably find a significant improvement in comfort and reduced energy usage right away. My crawl space used to get just above freezing during the winter months until I sealed the rim joists with 2" Foamular as well as closing off the two outside air vents. Now the crawl space stays around 63 degrees all year long.
Dave Sal is offline   Reply With Quote
Old 01-16-2014, 10:23 PM   #10
It is only because excessive dampness in a crawlspace or basement can condense, you can install a vapor barrier to protect floor framing from becoming damp and covered with fungus, efflorescence, and rot. A vapor barrier consists of one or more layers of sheet plastic on top of the soil in the crawlspace or basement.Use extreme caution when working with wood preservatives that contain pesticides.
michelclarke is offline   Reply With Quote
Old 01-18-2014, 11:29 AM   #11
Rewards Points: 39
Sorry, this week was busier than expected. Finally snapped a few pictures today.
My guess for the crawl space addition was sometime in the 1930's, but I haven't been able to find a permit.
Door from basement to garage
Original Stone Foundation
The joist were insulated with fiberglass, which will be removed once the walls and insulated.
All the walls are concrete except this 4' brick section
Door to the outside
Exterior view of the crawlspace
