Crawl Space Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 01-29-2014, 01:18 PM   #1
Crawl space insulation
Hello,
I live in Greenville, South Carolina. I have a 3 ft vented crawl space below town house unit and the wood floors are very cold and drafty. I have in place open web floor truss construction sitting on block stemwalls with rim plate. The trusses have R-19 insulation between, the crawl space has vapor barrier plastic on ground, edges not sealed. The R-19 appears to be faced with a vapor barrier backing on floor side, and insulation is held off bottom of floor sheathing with about 6 inches or more.
As an improvement, I know need to seal pipe penetrations and rim perimeter. I am not sure what the easiest improvement should be to the floor. I think that replacing R-19 with non faced (avoid trapping moisture)
R-30 insulation and maybe adding rigid insulation (no vapor barrier) to bottom of floor trusses. Or seal-off floor entirely with blanket insulation/ vapor barriers to bottom of floor trusses, sealing perimeter and open-up floor to hvac climate control by adding floor vents.
Are there any better ideas or problems with the ones I am proposing above?
cturlington is offline   Reply With Quote
Old 01-29-2014, 01:43 PM   #2
If it were me, I would remove the fiberglass batts, seal off the crawlspace floor properly as well as insulate the sides.
Queefer is offline   Reply With Quote
Old 01-29-2014, 01:53 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,558
Search the forum here for advice on converting the crawlspace to a "conditioned crawl".
That is going to be your best bet in most cases but we have to know more about your existing one. Any moisture issues?
Is there a vapor barrier down?
Crawl Space Cleanup/Insulation Outdoorbum Building & Construction 3 04-27-2013 06:27 AM
Crawl space and insulation.. valcarmo72 Building & Construction 8 02-23-2013 08:40 PM
crawl space insulation thevoz Building & Construction 6 01-09-2010 11:56 PM
Unvented crawl space insulation ehardman Building & Construction 3 01-13-2009 12:44 PM
Crawl space insulation howard.wheaton Building & Construction 10 10-21-2008 09:41 PM
