Crawl Space - Insulation - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 02:52 PM   #1
Kls
crawl space
should spray foam include beam pocket or header in dirt crawl space
Kls is offline   Reply With Quote
Old 11-20-2011, 11:19 PM   #2
Registered User
Rewards Points: 4,924
Welcome to the forums!
The beam (wood) needs the 1/2" air space at sides for anti-rot. Don't SPF it. Same with the headers, are you having this professionally done?
The dirt floor should be covered with a 6mill plastic vapor barrier to meet code.
Gary
Old 11-21-2011, 02:55 AM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 894
Is the beam wrapped in metal at the pocket or some other sort of impermeable protection?
Open sell SPF has a very high perm rating so it will allow drying through it.
Old 11-23-2011, 12:55 AM   #4
Registered User
What is your location?
If under the U.S. building Codes, any beam in a foundation wall requires a 1/2" air space on all sides and end for ventilation. Concrete foundations wick can moisture to the beam (called "rising damp" by BSC) even right through p.t. wood: http://www.ussteel.com/corp/construc...20Bulletin.pdf
With an open-cell foam surrounding wood with a water/moisture source, you would be courting problems:; ESP can absorb up to 4% water compared to a closed-cell (XPS) only 0.3%: http://docs.google.com/viewer?a=v&q=...t5jlOsa_kZRRgw
So any ESP touching the concrete can transmit and store water to promote rot of the wood nearby.
Is the crawlspace ventilated, since you are foaming?
Gary
Cement crawl space ventilation sheslostcontrol HVAC 9 05-22-2010 09:32 AM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 04:11 PM
32 inch high crawl space can a furnace fit tommar HVAC 4 02-20-2008 06:28 AM
Crawl Space In Basement -- Please Help thekid Building & Construction 7 01-04-2008 09:15 PM
