Covering Exposed Foamboard. Anything Options Besides Gypsum Board? - Insulation - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 04:29 PM   #1
Rewards Points: 156
Covering exposed foamboard. Anything options besides gypsum board?
If I've got pink board across the walls of my unfinished basement (only used for storage, home for hvac system & water heater) and I don't want to have inspection issues down the road (say if I sell the house), is there any material I can cover the board with besides drywall?
strategery is offline   Reply With Quote
Old 12-05-2011, 06:50 PM   #2
drywall would be my choice, it's cheap and easy to install. you wouldn't even have to mud it if you didn't want to. a lot of that foam gives off toxic fumes when it burns so it might be a lot safer covered with drywall.
Old 12-05-2011, 07:53 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,182
http://publicecodes.citation.com/st/...4_3_sec014.htm
Doesn't look like it.
Furring strips and drywall are probably your cheapest bet.
Old 12-07-2011, 12:08 PM   #4
Possibly Thermax polyiso sheathing since it can be left exposed to the interior without a thermal barrier.
http://building.dow.com/na/en/produc...xsheathing.htm
Or what about radiant barrier that has Class A / Class 1 Fire Rating (ASTM E84-10) for flame spread and smoke development?
johnk44 is offline   Reply With Quote
Old 12-07-2011, 08:16 PM   #5
Its foam, it will burn regardless of foil.
Drywall is cheap and will not be argued by any code official.
Old 12-08-2011, 06:58 AM   #6
Yeah, I wasn't sure about the radiant barrier being a viable option but thought that I would bring it up to hear other's comments.
I agree that drywall is a much cheaper option and readily accepted to meet code. But Strategery's original question was what other options were there besides drywall.
Old 12-08-2011, 07:02 AM   #7
Best thing to do is call you local building enforcement division and get it straight from them if you have questions. Some local codes can have superseding provisions when compared to the IRC.
Old 12-10-2011, 07:55 AM   #8
For this unconditioned space, is it true that the drywall doesn't even have to be mudded? If so, that would be awesome.
Particle Board Acceptable for wall covering in House? theatretch85 Carpentry 18 11-19-2012 04:58 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
covering asbestos with hardie board bigrig Remodeling 2 07-28-2008 08:18 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
