Could This Be Remains Of Vermiculite In My Attic? - Insulation - DIY Chatroom Home Improvement Forum
Old 10-11-2011, 03:04 PM   #1
Could this be remains of vermiculite in my attic?
My 1972 homes attic has what looks like vermiculite remains in it. It's scattered through the area above my garage where there's really 0 insulation. The rest of the attic has the pink instillation, but have no idea if there is any vermiculite under it. I don't want to mess with it knowing it might contain asbestos.
I have no clue if former owners removed most of the vermiculite or this is just something else. I did have the roof replaced so I'm thinking some of it is old roof remains, but I honestly dont know. I have no money to have it tested, but was planning on replacing my air handler and adding insulation to the attic come tax time. Knowing this might be vermiculite has me wondering if I'll even be able to do that now. I only learned about vermiculite the other night while watching one of Mike Holmes shows.
Any thoughts on if this could be vermiculite?
natetrain247 is offline   Reply With Quote
Old 10-11-2011, 03:25 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Leave it up to Holmes to alarm the public with his Chicken Little approach to everything.
If that was vermiculite, and that's all there is present, where did the rest of it go? If vermiculite was ever there to begin with! Doesn't look like any vermiculite/Zonolite I have ever seen.
Old 10-11-2011, 04:06 PM   #3
Asbestos isn't a problem if its undisturbed. If you are planning to add insulation, lay a plastic vapor barrier over the debrie and the place the insulation on top of this!
Asbestos isn't gaseous, so it can' infiltrate the drywall underneath and the vapor barrier over the top will encapsulate it.
Old 10-11-2011, 06:35 PM   #4
doesn't look like vermiculite to me.....but I am not charging you for that opinion. If you are worried about it, then you should have it tested.
1910NE is offline   Reply With Quote
Old 10-11-2011, 07:56 PM   #5
Thanks for the replies. I'm guessing its probably nothing more then just roof dust from when the roof was replaced.
Old 10-11-2011, 08:05 PM   #6
DIY staff
Rewards Points: 7,174
You beat me to it!!! Crumbs from a roof replacement----
Doesn't look like vermiculite at all---And I've seen a lot of it!
Old 10-12-2011, 08:00 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,606
+1
To be safe, try not to disturb it too much and just blow/insulate right over top if you want.
Vermiculite / Zonolite in the attic bobbybhb General DIY Discussions 17 11-16-2012 12:40 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Raccoons in the attic electricpete Pest Control 17 05-12-2011 04:02 AM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
Attic fan options P550 Roofing/Siding 1 08-22-2010 12:47 PM
