Correcting Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 05-17-2011, 11:00 AM   #1
Correcting insulation
This past November I moved into a Cape Cod style home. The second story has a knee wall on the south side of the house that I can access. The knee wall is completely insulated - floor, walls, and rafters. The insulation in the rafters is unfaced and right up against the wood board sheathing. Our inspector told us we might want to think about remedying this situation, but wasn't clear about how.
The house has soffits but no soffit vents, so do I need to pull down this insulation? There are gable vents and two roof vents - I can see up into the roof section through an opening in the ceiling (when I take down a light fixture) and there is not insulation between the rafters up there - only on the celing.
I also cannot access the knee wall on the north side of the house, so I have no way of knowing if things are installed improperly in that area.
Without soffit vents, should I bother taking down the insulation or installing baffles behind them? For what it's worth, the wood sheathing I can see appears to be in decent condition.
Is this the sort of situation that's worth going through the trouble of creating access on the other side of the house in order to see how things are installed over there?
Thanks for any input on this. Our house is in the northeast.
kellett117 is offline   Reply With Quote
Old 05-18-2011, 10:32 PM   #2
Registered User
Rewards Points: 5,212
Welcome to the forum!
I'd install an access to any attic over 30sq.ft., as per Code. Just to see if everything is A-ok.
The small attic behind the knee wall should have gable end vents if unable to tie the attics together via the insulated sloped ceiling, as should the attic above the sloped ceiling. That top ceiling needs your min. R-value for your area, as does the attic floor behind the knee-wall; find your zone- http://publicecodes.citation.com/ico...001_par001.htm
Find the R-value with your zone; http://publicecodes.citation.com/ico..._11_sec002.htm
Air block under the wall, and install housewrap on the attic side over the batts; http://www.homeenergy.org/archive/he...95/950309.html
http://www.simplesavings.coop/simple...ee%20walls.pdf
You need an air-space above the rafter insulation , is it drywall already
Knee-wall attic rafters shouldn't be insulated, only the floor.
Air seal first; http://www.familyhandyman.com/DIY-Pr...s/Step-By-Step
Gary
Old 05-23-2011, 05:32 AM   #3
Rewards Points: 95
Often roofs leak, often condensation forms on the inside of a roof and mold grows and wood rots.
In the recent past the best way to deal with this was to allow air to blow though and help dry the roof timbers and sheathing.
More recently we have come to understand that the passing wind that causes an area of low pressure to the lee of a home, does indeed pull air through the roof, but it also strips the warm air from our homes.
With the move to saving power the emphasis has changed to making homes air tight and to understanding the reasons why condensation forms on/in timber.
If you move the waterproof sheet insulation to a position two inches below the sheathing then any water that comes through the roof will run down and may disappear outside without causing any damage, more likely it will make the walls wet and cause damage there.
By filling the spaces between the rafters with a closed cell insulation like polystyrene and then adding another three inches of polystyrene below the rafters, you isolate
the inside comfort zone of the room from the cold air outside, this makes heating the room a lot cheaper (can be 90% cheaper depending where you live and how thick the insulation is)
The major problem with American light weight homes is that more than 1/8th of the surface is connected to the outside cold air and about the same is connected to the inside warm air, this vast amount of wood provides an express route out for our expensive air, wood is a very good conductor of heat, compared to polystyrene.
Insulating roofs, walls, ceilings and floors with 7 or more inches of polystyrene can save you a fortune on your heating and cooling bills.
Perry525 is offline   Reply With Quote
Tags
attic , baffle , cape , insulation , rafter
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
Correcting Insulation wcnorb Building & Construction 0 04-01-2006 05:30 AM
