Is This The Correct Tape For My XPS Seams? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-01-2013, 08:00 PM   #1
Is this the correct tape for my XPS seams?
http://www.homedepot.com/p/t/1004224...3#.UQxyzaXLSVo
ryanmcl is offline   Reply With Quote
Old 02-01-2013, 08:47 PM   #2
747
registered
747's Avatar
Rewards Points: 534
I would recommend 3M all weather flashing tape.
http://www.amazon.com/3M-Weather-Fla.../dp/B005AWY5FO
747 is offline   Reply With Quote
Old 02-01-2013, 09:00 PM   #3
wow... massive price difference. I will add it to my inventory list and see if i can afford it.
Old 02-02-2013, 03:18 AM   #4
3M all weather flashing tape is a good choice for exterior application. What you listed in your first post is fine for XPS interior application. Up here in Canada the equivalent is called Tuck Tape.
http://www.homedepot.ca/product/red-...es-long/951143
profcolli is offline   Reply With Quote
Old 02-02-2013, 08:45 AM   #5
747
registered
747's Avatar
Rewards Points: 534
Looks like OC makes some xps tape. Here it is.
http://www.owenscorning.com/literatu...-DataSheet.pdf
Old 02-02-2013, 04:11 PM   #6
Registered User
Rewards Points: 5,516
Interior, below grade, I'd use low expanding canned foam all around perimeter, then tape the seams, leaving a slight fold in middle for foam shrinkage. Exterior, allow for same- I'd tape over; mastic-mesh tape/backer rod/caulk, and flash the horizontal joints if your drainage plane w. WRB under the foamboard; http://www.buildingscience.com/docum...a-foam-shrinks
http://www.buildingscience.com/docum...nsulation/view
Gary
drywall seams analogmusicman Drywall & Plaster 9 01-28-2013 10:18 PM
allure flooring coming up at seams & corners Mavis Flooring 22 08-20-2012 02:07 PM
Tape Showing cougar01 Drywall & Plaster 3 03-09-2011 04:21 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 09:27 PM
Drywall Mudding - Tape Lifting Drywall_Dummy Building & Construction 5 09-06-2005 11:53 AM
