-   Insulation (http://www.diychatroom.com/f103/)
-   -   Is this the correct tape for my XPS seams? (http://www.diychatroom.com/f103/correct-tape-my-xps-seams-170781/)
ryanmcl 02-01-2013 09:00 PM
http://www.homedepot.com/p/t/1004224...3#.UQxyzaXLSVo
747 02-01-2013 09:47 PM
I would recommend 3M all weather flashing tape.
http://www.amazon.com/3M-Weather-Fla.../dp/B005AWY5FO
ryanmcl 02-01-2013 10:00 PM
wow... massive price difference. I will add it to my inventory list and see if i can afford it.
profcolli 02-02-2013 04:18 AM
3M all weather flashing tape is a good choice for exterior application. What you listed in your first post is fine for XPS interior application. Up here in Canada the equivalent is called Tuck Tape.
http://www.homedepot.ca/product/red-...es-long/951143
747 02-02-2013 09:45 AM
Looks like OC makes some xps tape. Here it is.
http://www.owenscorning.com/literatu...-DataSheet.pdf
Gary in WA 02-02-2013 05:11 PM
Interior, below grade, I'd use low expanding canned foam all around perimeter, then tape the seams, leaving a slight fold in middle for foam shrinkage. Exterior, allow for same- I'd tape over; mastic-mesh tape/backer rod/caulk, and flash the horizontal joints if your drainage plane w. WRB under the foamboard; http://www.buildingscience.com/docum...a-foam-shrinks
http://www.buildingscience.com/docum...nsulation/view
Gary
