The Correct Blocking Of Knee Wall Stud Bays That Meet A Sloped Roof - Insulation - DIY Chatroom Home Improvement Forum
Old 06-13-2012, 07:06 PM   #1
Rewards Points: 33
The Correct Blocking of Knee Wall Stud Bays That Meet a Sloped Roof
The 2x4 studs in the knee walls of the finished attic room in my 1950's 1.5 story house are cut to the roof angle and tacked to the rafters. The stud bays have no horizontal blocking at the top...
It appears to me that to properly block the stud bays in order to enclose the insulation batts, a simple 2x4 block will not suffice.
The Correct Blocking of Knee Wall Stud Bays That Meet a Sloped Roof-knee-wall-blocking.gif
A horizontal 2x4 block will leave a gap at the corner. An angled 2x4 block will not provide sufficient surface for sealing to the sheathings. A 2x6 trimed to a parallelogram in profile seems to be a solution. Is there better technique?
Lascaux is offline   Reply With Quote
Old 06-25-2012, 01:44 PM   #2
AGWhitehouse's Avatar
Option 1 (left) is easiest and the "empty" zone can easily be filled with insulation prior to drywall installation. It gives you nice flat nailing surfaces for both the drywall faces as well.
The 2x6 method would also work, but will be more money and more labor time for minimal thermal gains.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 06-26-2012, 02:20 AM   #3
How about option 1 and fill the void with spray foam?
Evstarr is offline   Reply With Quote
Old 06-26-2012, 07:06 PM   #4
No real need for it there and there is no backing to contain it upon expansion. The 2x6 rafter will have a 4" batt. in it already per that detail, so cutting the batt to the length/angle/etc. to accomodate the void would suffice.
Old 06-27-2012, 11:37 PM   #5
Registered User
Rewards Points: 526
I've always framed knee walls as Option 2, the drywall doesn't require fastening to the top plate unless a special shear/fire wall. Check with your local AHJ. Be sure to air-seal the joint at bottom plate/drywall/floor, per minimum Code.
Gary
Old 06-30-2012, 03:50 PM   #6
Rewards Points: 33
Gary
Wouldn't one also want to air seal at the top, in order to completely enclose the cavity? It seems to me that option 2 is the least preferable because it delivers the smallest contact surface and therefore the most potential for air leakage both at construction and if later shifting occurs.
Old 07-04-2012, 11:09 PM   #7
Registered User
Rewards Points: 526
I have ripped plates at an angle to fill the front top gap before (similar to 3). My reasoning is the rafters (roof) are directly tied to the studs/plates (wall) with less chance of drywall tape cracking at that joint when the roof flexes with the changing seasons/wind pressures. Solid framing holding the joint rather than paper tape.... You should also caulk the ceiling/wall drywall joint (at drywall install) to help as in ADA: http://www.buildingscience.com/docum...wall-approach/
Be especially careful at any electrical outlets and use a foam pad there, that 1/8" hole around it is about 1-1/2" square; Fig. 4; http://www.buildingscience.com/docum...wall-approach/
Any moisture in the wall would dry to the room side without a vapor barrier (not needed because of f.b. keeping cavity warm), but why let it in anyway?
Gary
Tags
blocking , framing , insulation , knee wall
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 09:14 AM
Finding angle where two roof slopes meet lindllc Roofing/Siding 4 11-10-2007 04:49 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Roof Sagging wall bowing christy123 Carpentry 37 12-29-2006 04:16 PM
