Conflicted About Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 03-01-2013, 05:05 AM   #1
Rewards Points: 874
Conflicted about Insulation
I have an exterior wall that I will be insulating and it is acing a busy road. I just read in another site that R-13 to 21 should be used for exterior walls but for sound control(which we want) to use R-11. But then it will be less enegy efficient but control sound better???? Thanks
Mstrlucky74 is offline   Reply With Quote
Old 03-01-2013, 11:48 AM   #2
Rewards Points: 194
I used R-13 when I insulated all of the exterior walls in my home and it worked well for sound control. I think R-11 is generally used for sound control in interior walls.
Larryh86GT is offline   Reply With Quote
Old 03-01-2013, 01:40 PM   #3
Registered User
Rewards Points: 5,516
I'm surprised R-11 is still around. Most areas are now requiring R-13, per minimum building code. R-11 was replaced with R-13 a while ago...R-11 fiberglass is very low density insulation. R-13 is medium density, R-15 is high density. R13 has 40% more material than R11, R15 has 180% more in a 3-1/2" wall cavity than R-11. http://www.huduser.org/Publications/pdf/walls.pdf
Denser is better for both thermal/sound barriers, IMO. Mineral wool would be my choice to surpress noise- STC rating of 52 vs. fiberglass= 46. #10 here; http://www.certainteed.com/resources...%20Control.pdf
http://www.roxul.com/files/RX-NA-EN/pdf/SafenSound.pdf
Gary
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
Dave Sal (03-01-2013), Mstrlucky74 (03-01-2013)
Insulation question for vaulted home Talgonadia Insulation 3 08-22-2012 06:06 AM
?'s about foil-faced "bubble wrap" insulation badger73 Insulation 5 06-25-2012 05:09 AM
Several Insulation Quotes, Big Decisions to make knotquiteawake Insulation 2 05-04-2012 11:16 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
