-   Insulation (http://www.diychatroom.com/f103/)
-   -   Conditioned or Unconditioned Crawl Space (http://www.diychatroom.com/f103/conditioned-unconditioned-crawl-space-176185/)
rickr86 04-03-2013 01:03 PM
What is my crawl space considered and what is the propper way to insulate the dirt floor and sidewall so I can use this space as storage?
http://imageshack.us/a/img818/192/img3439x.jpg
http://imageshack.us/a/img24/527/img3464m.jpg
http://imageshack.us/a/img21/3900/img3461l.jpg
http://imageshack.us/a/img6/8563/img3460ru.jpg
rickr86 04-03-2013 01:10 PM
This was before and the work shown above was done by the contractor (not hired by me)
http://imageshack.us/a/img442/3527/img0982oe.jpg
Windows on Wash 04-03-2013 04:56 PM
It appears to be unconditioned at this point.
Depending on the application, moving the insulation layer to the stem wall and supplying conditioned air to the space is usually best. You must install a proper vapor barrier across the soil and seal it to the stem wall as well.
Make sure your grading and water management at the foundation walls is good as well.
rickr86 04-03-2013 05:48 PM
Thanks but can I leave the insulation inbetween the flooor joist and add new insulation to the floor and stem wall with a vapor barrier? Also what do you mean by adding conditioned air? The crawl space is sealed and that door from the basement is the only air coming in (only when open for access). Do you mean adding a vent for outside air?
Windows on Wash 04-03-2013 06:00 PM
You can leave the insulation in there if you want to but it will serve no purpose.
By conditioned air I mean air from the conditioned spaces in the home (i.e. the vents) and it is best to have forced air supply via a duct extension to that space.
Gary in WA 04-05-2013 12:05 AM
Good crawlspace guide; http://www.buildingscience.com/docum...ance-and-codes
Another solution; http://www.buildingscience.com/docum...n-crawlspaces/
The insulation in the floor will keep the floor warm and slow heat transfer from above.
Gary
asinsulation 04-05-2013 10:04 AM
Just an fyi, before you contemplate bringing the crawlspace inside the building envelope, you may want to address any moisture issues if you haven't yet.
operagost 04-11-2013 04:18 PM
Gary, any documents that would help decide a strategy when one has an attached basement and crawlspace, and radiant rather than forced air heating? I've left all hydronic system plumbing uninsulated in the sealed crawlspace to keep it warm, but I'm afraid that might not do the job. My digital hygrometer says it's always dry to comfortable in there, but...
Nevermind; they say you can use a fan to pull make-up air from the house.
