Condensation In Unvented Flat Roof - Rigid Foam Board Installed - Insulation - DIY Chatroom Home Improvement Forum
Old 05-19-2017, 09:28 PM   #1
Rewards Points: 2
Condensation in Unvented Flat Roof - Rigid Foam Board Installed
Hello!
I have an addition on my house that was once a patio. They decided to box it in but leave the roof exposed/un-insulated. It is also un-ventilated without any central air and only a fireplace to heat it. I was looking to insulate that room to keep it warmer in the winter so I had a contractor come out and they suggested to insulate it with Rigid Foam Board. Which I had them do. (see attached images)
The problem is that there is now pretty bad condensation in that room. So much that it drips! I assume it's because the warm air inside is meeting the cold plywood of the roof therefore creating condensation. It is spring after all!
What I'd like to know is the following:
  • Is the issue that the roof doesn't have any room to breath?
  • How can I eliminate the condensation?
  • Was the rigid foam board a bad idea?
  • Do I need to take the insulation out?
  • Can I hold the contractors liable for this if it is an improper install?
Any advice is welcome!
Condensation in Unvented Flat Roof - Rigid Foam Board Installed-file.jpg   Condensation in Unvented Flat Roof - Rigid Foam Board Installed-file1.jpg   Condensation in Unvented Flat Roof - Rigid Foam Board Installed-file2.jpg
UndercoverNerd is offline   Reply With Quote
Old 05-20-2017, 07:42 AM   #2
Rewards Points: 4,290
Re: Condensation in Unvented Flat Roof - Rigid Foam Board Installed
"What I'd like to know is the following:
  • Ventilation is one option.
  • Eliminate any warm air from reaching a colder surface.
  • There is only one brand of foil faced rigid foam that can be left exposed, Dow Thermax.
  • You can have an unvented roof IF you follow the guidelines. Is that foam tight against the roof sheathing?
  • Can I hold the contractors liable for this if it is an improper install?"
  • Was a permit pulled and was the work inspected?
Bud
Bud9051 is online now   Reply With Quote
Tags
condensation , flat roof , moisture , rigid foam board , ventilation
Insulating unvented flat roof charliefreak100 Insulation 5 09-22-2014 06:56 AM
vinyl over aesbestos - how avoid nailing into wires? which foam board is best? gunner666 Roofing/Siding 12 08-07-2014 07:57 PM
Condensation On Foam board in basement tlh123 Building & Construction 1 02-12-2013 01:49 PM
Spray foam insulating ceiling under flat roof Jed Lukewater Remodeling 1 01-12-2009 07:22 AM
Flat roof headache The Barber Roofing/Siding 7 05-17-2008 05:48 PM
