Hello!
I have an addition on my house that was once a patio. They decided to box it in but leave the roof exposed/un-insulated. It is also un-ventilated without any central air and only a fireplace to heat it. I was looking to insulate that room to keep it warmer in the winter so I had a contractor come out and they suggested to insulate it with Rigid Foam Board. Which I had them do. (see attached images)
The problem is that there is now pretty bad condensation in that room. So much that it drips! I assume it's because the warm air inside is meeting the cold plywood of the roof therefore creating condensation. It is spring after all!
What I'd like to know is the following:
Any advice is welcome!
- Is the issue that the roof doesn't have any room to breath?
- How can I eliminate the condensation?
- Was the rigid foam board a bad idea?
- Do I need to take the insulation out?
- Can I hold the contractors liable for this if it is an improper install?
