Concrete Floor In 3 Season Porch - Insulation - DIY Chatroom Home Improvement Forum
Old 06-19-2013, 02:11 AM   #1
Rewards Points: 422
Concrete floor in 3 season porch
We are looking into building a 3 season porch in S/E Wisconsin, and are considering a concrete slab floor. Is it worth putting in 2 layers of 2" rigid foam under the slab, instead of just 1 layer? The porch will be about 12' X 19', with the floor about 16" above grade. Thanks.
Jim McC is offline   Reply With Quote
Old 06-19-2013, 08:08 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 2,024
For an extra 7 sheets of foam, I would go with 2" in total or just a 2" thick piece.
Old 06-19-2013, 03:29 PM   #3
Registered User
Rewards Points: 5,244
You need to understand slab heat loss in more detail. Most of the loss is at the perimeter which is why code (minimum) requires it there (4' in) for your location, Zone 6; http://publicecodes.cyberregs.com/ic..._11_sec002.htm
http://publicecodes.cyberregs.com/ic...9_4_sec003.htm
Normal slabs will mirror the air/surface temps, your slab is elevated which helps thermally, a little- depending on the capillarity of the soil; http://www.epa.gov/athens/learn2mode...enrys_map.html
You could get spring/summer condensation on the slab due to the winter lag temperatures, so; great you will insulate it all; http://www.buildingscience.com/docum...g-your-basment
Though 4" is too much for the middle areas, it is perimeter you should be really concerned with; http://www.google.com/url?sa=t&rct=j...hj_I6fU2ymaUSA
http://www.google.com/url?sa=t&rct=j...EcsiJQsJa02HLg
Gary
raised concrete slab porch tootie Concrete, Stone & Masonry 18 05-23-2012 11:19 AM
concrete porch issues.... need help JulesB Concrete, Stone & Masonry 15 05-17-2012 08:30 PM
Fix or Replace Porch Concrete Slab Majoram Building & Construction 10 06-25-2011 03:45 PM
mounting 4x4 wood post to concrete porch pshinaults Building & Construction 1 05-27-2010 03:53 PM
replace porch post on concrete slab maa40 Building & Construction 2 03-23-2008 11:50 AM
