Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 12-19-2011, 03:38 PM   #1
Cold spot in wall
In my bedroom i have a cold spot id say about 4x4 around electrical outlet, is this an insulation issue, (my breaker box is noy to far from the spot) i feel like its def making my bedroom colder than other rooms, can anyone help me out?
Ckb3216 is offline   Reply With Quote
Old 12-20-2011, 09:03 AM   #2
Exterior Construction
Windows on Wash's Avatar
Cold spot in wall
It is very common for insulation to get missed where it needs to be cut and spaced around properly.
Seam up the air leaks around that outlet and that will help. Here is not a whole lot you can do to insulate that missing chunk without opening up the wall.
Look at the bigger picture and improve where you can without having to demo things to fix insulation layers.
Old 12-20-2011, 03:45 PM   #3
Cold spot in wall
Ok thank you i bought the outlet foam inserts to insulate that area, thanks for the help
Old 12-21-2011, 04:22 PM   #4
Cold spot in wall
There is another possibility. You may have air intrusion from your attic, via the hole at the top of the wall framing through which your electrical cable passes. You would have to plug the area around the attic cable entry with caulk or spray foam. The foam receptacle insert helps, but you'll still have heat conduction through the drywall.
operagost is offline   Reply With Quote
Old 12-21-2011, 04:31 PM   #5
Cold spot in wall
I do not have an attic or Crawl space in my House, but thanks for the response
Old 12-21-2011, 04:33 PM   #6
Cold spot in wall
Im assuming it was not insulated well in that area i had bought those outlet insulation inserts and installed them to help, hopefully i see a difference, thanks for your help guys
Old 12-21-2011, 08:58 PM   #7
Cold spot in wall
The drywall gaskets are okay if used properly.
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Cold spot on interior wall Hogslice Building & Construction 4 12-20-2009 02:57 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 04:49 PM
