-   Insulation (http://www.diychatroom.com/f103/)
-   -   Cold spot in wall (http://www.diychatroom.com/f103/cold-spot-wall-127072/)
Ckb3216 12-19-2011 03:38 PM
Cold spot in wall
In my bedroom i have a cold spot id say about 4x4 around electrical outlet, is this an insulation issue, (my breaker box is noy to far from the spot) i feel like its def making my bedroom colder than other rooms, can anyone help me out?
Windows on Wash 12-20-2011 09:03 AM
It is very common for insulation to get missed where it needs to be cut and spaced around properly.
Seam up the air leaks around that outlet and that will help. Here is not a whole lot you can do to insulate that missing chunk without opening up the wall.
Look at the bigger picture and improve where you can without having to demo things to fix insulation layers.
Ckb3216 12-20-2011 03:45 PM
Ok thank you i bought the outlet foam inserts to insulate that area, thanks for the help
operagost 12-21-2011 04:22 PM
There is another possibility. You may have air intrusion from your attic, via the hole at the top of the wall framing through which your electrical cable passes. You would have to plug the area around the attic cable entry with caulk or spray foam. The foam receptacle insert helps, but you'll still have heat conduction through the drywall.
Ckb3216 12-21-2011 04:31 PM
I do not have an attic or Crawl space in my House, but thanks for the response
Ckb3216 12-21-2011 04:33 PM
Im assuming it was not insulated well in that area i had bought those outlet insulation inserts and installed them to help, hopefully i see a difference, thanks for your help guys
Windows on Wash 12-21-2011 08:58 PM
The drywall gaskets are okay if used properly.
