Cold Room Insulation - Insulation - DIY Chatroom Home Improvement Forum
Old 06-27-2013, 08:01 PM   #1
Rewards Points: 326
Hello All
Could anyone please help me better insulate my basement cold room inside and maybe out? Here are some areas i was thinking about fixing up or better sealing the cold air in!
1. Right side of door on the inside
a) yes, in between the concrete and the door frame, is the pink stuff that is wrapped over the cement on the outside and its exposed.
2. Top of door on the inside
a) yes, that white stuff is just loosy goosy. i could just pull it out
3. Left side
a) yes, 1 inch gap between door frame and concrete that is empty! and if you can peek in and see the pink stuff that wraps the outside
4. Left side of outside of door
5. Right side of door
6. Top of door on outside
Cold Room Insulation-20130627_185508-1-.jpg   Cold Room Insulation-20130627_185515-1-.jpg   Cold Room Insulation-20130627_185525-1-.jpg   Cold Room Insulation-20130627_185603-1-.jpg   Cold Room Insulation-20130627_185622-1-.jpg
Amitabh is offline   Reply With Quote
Old 06-27-2013, 08:31 PM   #2
Rewards Points: 2,638
So are you trying to better seal the door so that in the winter heat is not escaping into the cold-room, or do you have a problem in the summer that your cold-room is not cold?
SPS-1 is offline   Reply With Quote
Old 06-27-2013, 09:04 PM   #3
Rewards Points: 326
both
in the summer, its not that cold
in the winter, heat leaks through, and my furnace and vents are around it.
PTMD
Old 06-27-2013, 09:40 PM   #4
You can possibly put Great Stuff type product in any gaps, but I expect any improvement will be negligible. I see weatherstripping around the door, that's good. Make sure you have a door sweep to seal the bottom. If that is a hollow door, then you will be loosing some heat through the door. In the summer, heat gain to the cold-room is mostly through the walls and ceiling of the cold-room. What is above it, a porch pad that gets direct sunlight? A couple of inches of extruded polystyrene on the walls and ceiling of the cold room would help insulate it. In your house, a protective barrier of drywall or similar is required over XPS, but I am not sure if that applies to a cold-room
Old 06-28-2013, 08:03 AM   #5
Rewards Points: 326
What is XPS?
Old 06-28-2013, 09:09 AM   #6
extruded polystyrene insulation. The heavier, more expensive stuff. Better insulation than the lightweight stuff.
What can I do about the cold coming into this room?? WillK Building & Construction 25 09-01-2015 02:02 PM
Possible to create cold room from this mistake? Noob1 Building & Construction 17 10-26-2011 06:18 PM
transformed my cold room into a wine cellar marie-josee Building & Construction 1 09-20-2011 09:00 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
What is cold room for? KUIPORNG Remodeling 4 04-26-2007 05:06 PM
