Cold Master Bathroom (from Shower I Think) - Insulation - DIY Chatroom Home Improvement Forum
Old 11-02-2013, 12:50 PM   #1
Cold Master bathroom (from shower i think)
I have a cold master bathroom. I think it is from my fiberglass stand up shower. when i get up into my attic it looks like there is no insulation on top of the shower. Im not sure if moisture can vent up in to that area. What is the best product i can use to insulate above my shower but will not mold if water vapors get to it. it is a small shower no bigger then 4x4.
Todd
Todd_B is offline   Reply With Quote
Old 11-02-2013, 02:38 PM   #2
Registered User
Rewards Points: 4,912
Location, location, location...
Gary
Old 11-02-2013, 02:47 PM   #3
Rewards Points: 12,812
Unless for some strange reason there is no ceiling in this room there's 0 reason for not having insulation over that bathroom.
How much depends on your location.
It's best to go back and add it to your profile. Just go to quick links to edit.
Old 11-02-2013, 02:53 PM   #4
location as in where i live..Out side of Salem or.
location of the bathroom.. east side, showers on an exterior wall.
Sorry in new to this site.
Old 11-02-2013, 02:58 PM   #5
Im not sure if there is a ceiling over the shower, its caped by the top of the shower and dry walled at the top front of it. I think i can see the fiberglass on the top of the shower from the attic. i have to go up there soon to fix another problem i will look to verify this.
What are my options for insulation on the fiberglass shower if that is what i see.
Old 11-02-2013, 03:01 PM   #6
Is the rest of the ceiling insulated?
http://www.energystar.gov/index.cfm?...sulation_table
There was suppose to be about 12" of insulation in that whole attic, plus insulation under the floors.
Old 11-02-2013, 03:07 PM   #7
yes it is. the whole attic has blown in in it. Its not in the best of shape but that's why im trying to figure out what to use over the shower. Then I'm going have some hvac work done up there, then im going to have the blown in redone.
Old 11-03-2013, 03:24 PM   #8
Registered User
The thermal barrier needs to be continuous across the attic floor, why is there no insulation above the shower; why can you SEE the shower from above?
Is the shower in an alcove or dropped ceiling, separate from the main ceiling line (plane)?
Gary
Old 11-03-2013, 11:49 PM   #9
how this
Old 11-04-2013, 09:38 PM   #10
Registered User
Either air seal/insulate the dropped ceiling or air seal/insulate above the area as per page 20; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
Gary
Condo Master Bathroom Reno (demo, bathtub to shower conversion, flooring) LeviDIY Project Showcase 24 05-09-2011 02:55 PM
Bathroom ceiling with vapour barrier - shower light / exhaust fan mforeman1 Drywall & Plaster 1 04-03-2011 07:19 PM
can't get cold enough in my shower now diyrb01 Plumbing 4 09-14-2010 07:24 AM
Bathroom shower surround StevePax General DIY Discussions 0 11-12-2009 01:31 PM
shower gets cold bannisterdl Plumbing 2 07-29-2009 07:43 AM
