Closed Cell Spray Foam For Waterproofing? - Insulation - DIY Chatroom Home Improvement Forum
Old 03-02-2013, 09:08 AM   #1
closed cell spray foam for waterproofing?
One of my kids has a rowhouse in Baltimore built around the time of the Civil war. The walls are two layers of brick separated by an air space with a perpendicular coarse about every 6 coarse to tie the long ways laid brick together. Some sections of the wall leak after a rain. We are working on regrading to divert the water away from the wall but, I don't think that regrading will be enough to stop the water. There is really not enough room to excavate next to the wall for exterior foundation sealing or a perimeter drain. I am wondering if injecting closed cell insulation into the space between the two rows of brick would effectively seal out the water. Does anyone have any thoughts or experience? Thanks
dads fixit is offline   Reply With Quote
Old 03-02-2013, 09:55 AM   #2
Rewards Points: 13,296
Got some pictures?
Foam is going to do nothing to seal it.
Sure those are not weep holes that need to be there to dry out behind the wall your thinking of filling?
Missing morter needs to be ground out and refilled with new morter.
Old 03-02-2013, 10:10 AM   #3
There are no weep holes in the wall presently. As far as the mortar joints go I can't see them to evaluate their condition. I was thinking that since foam does not absorb water that it may effectively reduce or stop the water penetration into the basement. Of course the added insulation value would be a plus too. Why is closed cell insulation not a good water sealer?
Old 03-02-2013, 11:30 PM   #4
Registered User
Rewards Points: 5,216
http://www.buildingscience.com/docum...sure-guideline
Gary
Old 03-03-2013, 09:31 AM   #5
Thank you. That is great information.
The Following User Says Thank You to dads fixit For This Useful Post:
Gary in WA (03-04-2013)
Spray foam in attic diystephen HVAC 6 12-29-2012 02:07 PM
Spray Foam in Walls & Moisture Question leeave96 Insulation 4 11-12-2012 12:43 PM
Closed Cell spray foam kits jimleahman Insulation 8 01-06-2012 04:06 PM
Spray Foam Installation Problems Ron6519 Building & Construction 7 07-11-2011 02:50 PM
closed cell insulation in attic Dennis Doucette Building & Construction 7 03-16-2007 10:08 PM
