Cinder Block Perimeter In Garage Question? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 03:51 AM   #1
jpc
jc
Rewards Points: 162
Send a message via Yahoo to jpc
cinder block perimeter in garage question?
Hello everyone, and thanks in advance for any help or advice.This forum is an awesome resource,so again thank you to all the pro's and contributing members. I live in chesapeake va,house is on a crawlspace and you step down about 4 steps to the garage,along the perimeter at the bottom of the walls is about 1 1/2 - 2 inch edge of the block, This weekend im going to be blowing insulation in my attic, and I ordered a bit extra to try and blow into already finished wall's where ive found there to be no insulation, what do i need to do with the cinder block as far as sealing or following suit with what im doing this weekend? I have no idea, do i cover it, leave it , any help is appreciated....Ohh and if anyone has any tips or suggestions for trying to blow into the walls, its my first time doing this so , Im all ears
jpc is offline   Reply With Quote
Old 02-18-2012, 06:29 AM   #2
Stay-at-home GC
Are you planning to fill the hollow cells of the block? I'm a little confused on that point.
If you know the rate of application on your blower nozzle you can calculate the time to fill the volume of each wall cavity.
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 02-18-2012, 05:05 PM   #3
jpc
jc
Rewards Points: 162
hey thanks for responding, well thats just it, i didnt have a plan for that part, didnt know if ya did something to or covered it or let it be, Im thinking i over thought it didnt I?,
Old 02-23-2012, 05:05 PM   #4
Stay-at-home GC
Any pics? That would help.
Chesapeake VA, spent a month or two down there in the Great Dismal Swamp.
Old 02-23-2012, 05:38 PM   #5
concretemasonry's Avatar
Rewards Points: 2,594
I lived in Chesapeake (Riverwalk area off Battlefield) for a few years and our house had 8" high block around the slab with the framing on top to keep the wood away from the moisture. We never had an occasion to worry about insulation in the garage after coming from the north, since it really did not make sense at that time.
DevilDog - The Great Dismal Swamp is certainly an appropriate name if you have ever drive by it or tried to navigate around it. It is huge and dismal.
Dick
concretemasonry is offline   Reply With Quote
Old 02-24-2012, 01:26 PM   #6
jpc
jc
Rewards Points: 162
I just now seen that there was another responce on this thread , I apoligize.I wasnt able to get any pics uploaded yet, but what i ended up doing was cleaning the side and top edges that are visable , and any where there was gaps or chips in grout i sealed up with stuff for mortor from the box store and plan on getting to my garage walls this weekend since I didnt get to them last weekend,which i have another thread posted concerning the proper technique on that.
I live about 2 minutes from the dismal swamp, huge and boring area lol, thanks ya'll
Tags
garage
glass block perimeter channel in brick wall amakarevic Building & Construction 10 05-03-2011 09:12 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Wire through cinder block drjay9051 Electrical 1 12-07-2010 12:42 PM
Garage Ventilation Question eagle09tbl HVAC 5 10-22-2009 09:24 PM
Cinder block home ibrrhobo Building & Construction 9 08-20-2009 07:05 AM
