Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 08-07-2012, 09:36 AM   #1
RockfordChimney
Post
Chimney Liner Insulation
I thought my fellow DIY'ers would enjoy this information. Fall and winter are upon us soon enough... don't forget about your chimney!
Do I really need to insulate my chimney?
When installing a chimney liner, it is highly recommended to insulate the liner. The insulation helps ensure safety and efficiency for the stainless steel, flexible chimney liner. Insulation also reduces the risk of buildup of creosol (a constituent of creosote buildup that starts chimney fires) and helps the chimney stay cleaner longer.
You usually have two choices when insulating your liner.
You can use an insulation wrap blanket
or You can use an insulation pour down mixture
Hope this helps, Happy DIY'ng!
Rockford is offline   Reply With Quote
Old 08-07-2012, 03:25 PM   #2
We use vermiculite mixed with a bit of cement to help stabalise the mix here for flues. Is that a similar type of mix to yours?
stuart45 is offline   Reply With Quote
Old 08-13-2012, 10:22 AM   #3
RockfordChimney
Yes it is similar, it's vermiculite based
Tags
chimney, chimney liner, insulation
How to install chimney liner Rockford How To Guides 3 07-16-2012 05:15 PM
Basement Exterior Above Grade Insulation purpasadu Building & Construction 6 02-28-2012 05:42 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 09:49 AM
does my chimney need a liner? amakarevic HVAC 11 05-26-2011 02:53 PM
