Chimney - Insulation - DIY Chatroom Home Improvement Forum
Old 01-24-2014, 08:06 AM   #1
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
Chimney
Can I or should I put insulation around my chimney in my attic, and if yes, which kind should I use?
Barry
Barry J is offline   Reply With Quote
Old 01-24-2014, 08:45 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,294
Not really necessary.
It should be properly air sealed to the attic floor as a default.
Old 01-24-2014, 08:48 AM   #3
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
How should I "air seal"???
Old 01-24-2014, 09:10 AM   #4
You want to use a non-combustible against the fire place and give yourself enough room to accommodate the insulation thickness.
This is the only picture that I could find and it doesn't illustrate the building upward of the sheet metal but it does show them insulating the chimney with roxul.
Old 01-24-2014, 09:44 AM   #5
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
I've seen aluminum foil wrapped around the bottom part of chimney in a home improvement book, what does that do???
Old 01-25-2014, 11:19 AM   #6
Keeps the combustibles off the brick.
Old 01-25-2014, 01:19 PM   #7
Registered User
Rewards Points: 526
If the attic is ventilated it will be close to the outside air temperature. If so, and you have trouble with back-drafting when cold outside, insulating it will help. "Cold hearth"; http://woodheat.org/fireplace-tight-house.html Be sure to use an air-barrier around it after insulating (to prevent BackD) as Roxul is air permeable and subject to wind-washing in most ventilated attics.
Gary
Old 01-31-2014, 10:16 AM   #8
DIY Homeowner
Barry J's Avatar
Rewards Points: 232
The attic is ventilated and as cold as the outside. Right now I have to tackle the air sealing with fire barrier caulk, if I was to add more metal when I seal, is window/ door flashing alright to use???
After I seal, I'll add some unfaced batts around the chimney over the original insulation.
Can I place the batts right against the chimney??
Also, I don't know if this matters, but it's my chimney that ventilated the oil furnance. I have no fireplace
Old 01-31-2014, 04:36 PM   #9
Use Roxul and the batts are fine. You can cover them with a housewrap (tyvek) to prevent the wind washing.
Old 01-31-2014, 08:46 PM   #10
Registered User
Rewards Points: 526
The link left an air space around the chimney, required per code. This is one of those local interpretations where asking the local AHJ is the answer. http://www.greenbuildingadvisor.com/...terior-chimney
pp.37; http://www.buildingscience.com/docum...sealing-guide/
Codes can be tricky; http://www.rumford.com/code/fireblocking.html
Following the code, the unfaced fiberglass batts- no loose-fill- require 16" tall for acceptable fire-block of vertical spaces....... http://publicecodes.cyberregs.com/ic...002_par019.htm
Gary
How to install chimney liner Rockford How To Guides 3 07-16-2012 04:15 PM
Why a Chimney Liner? Rockford HVAC 0 07-12-2012 10:03 AM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 10:00 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
