Chase Insulation Prevent Flu Fires - Insulation - DIY Chatroom Home Improvement Forum
Old 10-12-2013, 03:36 PM   #1
Unhappy
Chase insulation prevent flu fires
We moved into our house 13 years ago and replaced the woodstove. The chase is an external box attached to the house with pipe going up the middle of it. We have a chimney cleaner come two times a year and still have fires every year in that pipe that turns it an evil glowing red pipe in and out of the house. We have had it replaced. Our woodstove pipe has two 45 degree bends inside the house until the pipe leaves the wall of the house and runs approx 15-20 feet up. We can get a draw but we get horrid creosote buildup and the only other suggestion we have got is to insulate the existing chase around the pipe. Any suggestions on how to do that and what materials we would use???
moniqueadams is offline   Reply With Quote
Old 10-12-2013, 04:30 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,554
I would seriously consider a rebuild or redesign of the flue first and foremost.
While keeping the fire contained and insulated from the structure is wise, it should be combined with a flue that doesn't tent to create build up.
In terms of the insulation materiel, rockwool or mineral wool (same thing) is your best. Roxul is a brand that is often used.
Old 10-12-2013, 04:31 PM   #3
Rewards Points: 14,278
I've never heard of anyone having to insulate a stove pipe.
Just a guess because we have so little info but more often then not it because of an over sized pipe or an issue with the cap on the top.
What's the sweep have to say about it?
Old 10-12-2013, 04:39 PM   #4
We did replace the pipe last year and the chimney sweep really is perplexed and says the only other thing he can think of is to insulate the pipe outside the house to create a better draw and keep the pipe warmer but also said he didn't know how to go about doing that.
Old 10-12-2013, 05:49 PM   #5
Time for a new sweep.
Old 10-12-2013, 06:30 PM   #6
DIY staff
Rewards Points: 7,174
How large is the flue? Sounds like it is oversized for your stove.
Old 10-13-2013, 10:46 AM   #7
Rewards Points: 240
is this stove pipe ?
Fix'n it is offline   Reply With Quote
Tags
chase , chimney , insulation
Attic Insulation Help Needed-What type, etc HandyFrank Building & Construction 9 12-15-2011 01:54 PM
Yes, Another Basement Insulation Question Beepster Insulation 7 11-30-2011 06:30 PM
Newbie questions on refinishing walkup attic with knee walls FileOpen Insulation 2 11-19-2011 11:31 PM
Fixing multiple attic electrical issues before blowing in insulation darlingm Electrical 11 11-19-2011 09:19 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 02:33 PM
