Certainteed Greenguard Insulation-irritating? - Insulation - DIY Chatroom Home Improvement Forum
Old 02-14-2012, 04:45 PM   #1
Certainteed greenguard insulation-irritating?
They put Certain teed Greenguard insulation in the walls yesterday and the vapor or gas has been really irritating to my throat and my eyes have burned-last night pretty bad. It's better today after I left windows open (and heated the outdoors).
I'd used just normal HD pink insulation in the ceiling over the weekend without that problem at all-just the usual little irritation to eyes.
Is it common for the newer insulation to be so irritating? What's in it?
canoes is offline   Reply With Quote
Old 02-14-2012, 05:05 PM   #2
Rewards Points: 626
yep its off gassing of the formaldehyde.
Nailbags is offline   Reply With Quote
Old 02-14-2012, 05:15 PM   #3
Rewards Points: 1,092
Originally Posted by canoes View Post
...and the vapor or gas has been really irritating to my throat and my eyes have burned-last night pretty bad...
Or dust in the air. Did a good cleaning happen after installation?
Old 02-14-2012, 05:51 PM   #4
I thought the "green guard" would be formaldehyde free. It's even marked "school safe", though it doesn't say formaldehyde free. The subcontractor put it in.
The pink stuff from HD I used over the weekend was marked formaldehyde free.
I did clean it up some today, I couldn't be down there last night it was so bad. I would not recommend this brand. Whatever is in there can't be healthy.
Old 02-14-2012, 06:17 PM   #5
Rewards Points: 626
Here is the MSDS on it it has 3-9% Formaldehyde in it anything less then 10% can be called Formaldehyde free.
http://www.certainteed.com/resources...ion%20MSDS.pdf
Old 02-14-2012, 06:51 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
Probably a combination of the two.
I would air the place out and see what you get.
Old 02-14-2012, 07:12 PM   #7
Thanks. I'll air it out more tomorrow afternoon when the weather should be nicer.
Nailbags, thanks for the MSDS link. I looked at it briefly, but completely skipped over the formaldehyde since the left column next to that was blank. There's a remarkable difference between the two brands (which I'll mention to the contractor). I also sent the Certain Teed company a note.
Attic insulation over old attic floor beffreyj3 Insulation 6 11-18-2011 07:21 AM
Which insulation? Photos attached of room homiefb Insulation 1 08-16-2011 05:44 AM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Rafter Vents and Insulation nofx1981 Roofing/Siding 15 03-10-2010 08:14 PM
Has anyone used Green Fiber blown in insulation? pomelo Building & Construction 7 02-10-2010 07:17 AM
