Celluse In Attic, Adding A Floor - Insulation - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 07:18 AM   #1
Celluse in attic, adding a floor
Hi All,
I currently have a walk in attic that was insluated by the previous home owner with Celluse blown in insulation. I would like to put a floor on the attic and finish this space. I will be insulating and vapour barriering the roof, but my question is for the floors. Should I remove the celluse or just floor right over top of it? And if I floor over top is there anything I should do first?
As this will be finsihed space and used quite often I am concerned with this being under the floor and getting disturbed as I walk on it. I know that celluose is not really a health concern (for now). But even if it is not, I am just thinking of the dust that may come out and should I just remove this before I floor?
Thanks in advance,
Mike
mikelscrole is offline   Reply With Quote
Old 02-28-2013, 09:14 AM   #2
Rewards Points: 14,000
#1 Are you 100% sure the floor joist are sized to allow a finished floor?
If you lay a proper subfloor with T&G 3/4 how is any dust going to get into the room?
Going to need a permit to add that room and make sure your egrees meets local codes.
Old 02-28-2013, 10:51 AM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
+1 to Joe's recommendations. The cellulose in the floor between two conditioned spaces will neither help nor hurt any thing much. I'd leave it in, maybe it will help sound travel a little bit. Your main concerns are going to be making sure that the construction of the finished space (including floor structure) and the insulation/sealing that you add around it are up to snuff.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 02-28-2013, 10:15 PM   #4
Thanks for the info, I will get in an expert to confirm the flooring supports to be safe. The structure did have a floor (1" planks) prior to the previous owner having it professionally removed with the Vermiculite that was under it originally.
Blow insulation OVER attic floor? Garblefarf Insulation 10 01-17-2013 04:14 PM
Laying attic floor: what should I do about exposed wiring? scool Electrical 6 11-11-2010 11:23 AM
Adding insulation to only a portion of an attic? curls00 Building & Construction 22 10-27-2008 09:41 AM
Molde: Underside of Attic Floor stangboy68 Building & Construction 9 12-06-2007 09:53 AM
adding a second floor chubdo Building & Construction 11 04-16-2005 12:20 AM
