Cellulose In Walls: Can't Find Blower Machine... - Insulation - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 09:48 AM   #1
Rewards Points: 37
Cellulose in walls: can't find blower machine...
Hey team,
I'm looking for a machine to dense pack cellulose in my wall studs. I already made 4 inch holes in the walls. I went to my local Lowe's and the machine they have is only for attics (I called Greenfiber, and it says I need a different machine for dense packing walls).
The Lowes and HD's in my area only have it for attics. Any idea where I can get the machine for walls?
It's similar to this: http://www.proxibid.com/asp/LotDetai...4&lid=11590260
Thanks a lot guys, my house currently has 100+ 4 inch holes in the walls.
aminus21 is offline   Reply With Quote
Old 12-15-2011, 10:32 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
I didn't know dense pack cellulose could be blown into a hole in the wall. The only kind I have seen is damp with glue, shot into the walls and smoothed off. I have see Styrofoam beads blown into holes in walls but the holes were smaller.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-15-2011, 11:30 AM   #3
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I've always seen 2" holes for this. Maybe call a tool rental place.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 02:20 PM   #4
concretemasonry's Avatar
Rewards Points: 2,578
It could be a process that only some contractors want to do the education on and invest in.
Shooting at an open wall face and leveling is possible and done every day, but going through holes that are already drilled/located and providing a real guarntee is a real barrier.
Dick
concretemasonry is online now   Reply With Quote
Old 12-15-2011, 03:10 PM   #5
Rewards Points: 244
I would check with your local tool rental places. If no luck there then maybe work with a contractor to get a good price since you've already cut the holes. Maybe you can find someone to work with you so you can use the proper machine. Good luck!
cbaur88 is offline   Reply With Quote
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
Green Fiber in walls lukabrazi Building & Construction 1 02-28-2011 12:54 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
Old old linoleum, can it take paint? molamola Painting 23 11-11-2008 07:32 PM
