Cellulose Vs Foam? - Insulation - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 01:07 PM   #1
Cellulose vs foam?
I am building a new home in Illinois and would like to know if I should go with the wet cellulose or the spray foam. The foam costs double. I am having geo thermal installed so I want to know which route would be best. Thanks.
Sent from my iPhone using DIY Forum
Hendo is offline   Reply With Quote
Old 01-31-2012, 01:10 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,862
What is the construction of the home?
Open cell foam and cellulose will have similar R-Values but the foam will be a true air barrier and installation is less technical to have it done correctly.
Have you selected a brand of cellulose? I hope you are using borate stabilized only in that case.
The added money you will be saving in foam should be applied to the exterior wall insulation detailing (i.e. rigid foam to the outside wall for a thermal break).
Where is the home located, construction type, wall depth, etc?
Old 01-31-2012, 01:55 PM   #3
I am building the home myself. It is a 60 x 40 house with a 40 x 40 attached garage. The walls are 2 x 4.
Old 01-31-2012, 02:01 PM   #4
What are the exterior walls going to be?
Where is the home located?
Old 01-31-2012, 02:36 PM   #5
The home is located in southern Illinois along I-70. The walls are 2x4. The wet cellulose I got a quote for is forest-wool insulation. It's about $5500 and the foam is about $8500. Including the attic with dry cellulose on both estimates.
Old 01-31-2012, 02:43 PM   #6
Make sure it is borate only cellulose.
What is the exterior construction (i.e. siding, stucco, brick, etc.)?
Old 01-31-2012, 02:57 PM   #7
It will have vinyl siding and a metal roof.
Old 01-31-2012, 06:15 PM   #8
Exterior foam is your friend in this case.
You could also turned the attic into conditioned space if you so desire by putting enough rigid foam to the outside layer as well.
Old 02-03-2012, 04:06 PM   #9
Rewards Points: 1,092
Hendo: Curious. That is a fairly large house, esp w/ the garage (I assume heated?) and Illinois can be cool, or hot (your location?). Have you considered a slightly thicker wall (double stud 2x4) and dense packed cellulose(dry)? Cellulose is more environmentally friendly than foams, and you can diy the dense packed.
Insulation - Cellulose vs. Icynene meth Building & Construction 25 12-17-2014 11:04 PM
Insulation: foam or cellulose? wombosi Insulation 1 07-06-2011 09:20 PM
Floor insulation, cellulose vs hard foam Arky217 Flooring 0 12-23-2010 11:44 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Hybrid wall insulation consisting of 2" rigid foam + 2x4 fiberglass batts? TitaniumVT Building & Construction 15 09-14-2010 03:50 AM
