Cellulose Insulation Blowing In Walls
The foam that they put into the walls with existing fiberglass, fills the voids and makes it aound tight, and can make it more air tight to make more efficient.
A reputable company will do a blower door test before and after the install. A good one will pull in every rebate available to you, which will lower your end bill.
What I would do for now, use DAp foam in the can around outlet boxes on outside walls, along with any gaps around the window and door framing. Insulate with R-15 or R-13 around rim and sill joist bays in basement or crawl. Also insulating the underneath of the floor can help to make it not radiate coolness.
Also sealing around the attic hatch, damper for bath exhaust fan, better dryer damper that looks like a mushroom. Also better sealing gaskets around entry doors, and if windows leak when closed, use 3m window film.
That should get you by this winter, but the other will help in the long run.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Now listen, Cadet. I've got a job for you. See this button? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : Don't touch it! It's the History Eraser button, you fool! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : So what'll happen? To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. : That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
