Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Insulation
Old 11-10-2012, 07:47 PM   #1
Cellulose Attic Insulation Question.
I want to add some more insulation in my attic. I have FG blown in there now. It is just above the joist's. It's higher in some spots but not much. I would like to use blown in cellulose. Is this ok? TIA...
WGFA is offline   Reply With Quote
Old 11-10-2012, 11:27 PM   #2
Moderator
Check the thickness of drywall on ceiling, 1/2" at 24"oc framing = 1.6# per sq.ft. or R-49 minus the f.g. weight. 16"oc framing will take 2.2# per sq.ft. as will 5/8" drywall, or R-60; http://www.greenfiber.com/step_one_-...o_install.html
Insulation chart, Table 2; http://www.lafarge-na.com/GA-216-07_English.pdf
You will compress the f.g. with progressively more cellulose, degrading its R-value; http://www.greenbuildingadvisor.com/...fiberglass.JPG
Air seal the attic first and foremost; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
I'll help you find them; http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Gary
Some
Clothes taking longer to dry?
The Following 2 Users Say Thank You to Gary in WA For This Useful Post:
gma2rjc (11-19-2012), WGFA (11-12-2012)
Old 11-12-2012, 10:45 PM   #3
Thanks for the info...
Old 11-13-2012, 02:26 AM   #4
The cellulose will also "seal" the blown fiberglass. Blown fiberglass is best dense packed into walls. Loose in the attic I don't think it is quite as good as cellulose; too fluffy.
The Following User Says Thank You to jklingel For This Useful Post:
Windows on Wash (11-13-2012)
Old 11-13-2012, 10:26 AM   #5
I have a question regarding table 2 in the lined gypsum document. My interpretation is that the 1.6# per sq ft applies to wallboard. Further down in the table it specifically states ceiling board = 2.2# per sq ft. Please help me understand.
fstr is offline   Reply With Quote
Old 11-17-2012, 01:48 PM   #6
Moderator
That would be special "ceiling board", rated as stiffer/stronger for ceiling insulation-framing spacing with insulation loads only. Sorry, no links now as continuing IP problems on my end. Sorry for the late answer.
Gary
Attic insulation question.... jamjr74 Insulation 1 02-08-2012 05:28 AM
Attic Insulation Question mfrauenhoffer Insulation 4 02-07-2012 04:12 PM
Attic insulation question MrBillCSI Insulation 1 02-03-2012 10:25 AM
Finishing an attic...insulation question... slyons Roofing 6 06-18-2011 09:36 PM
Insulation, Ventilation in Cape Cod Side Attic Get'n er done Building & Construction 10 12-03-2010 12:38 AM
