-   Insulation (http://www.diychatroom.com/f103/)
-   -   Cellulose Attic Insulation Question. (http://www.diychatroom.com/f103/cellulose-attic-insulation-question-162875/)
WGFA 11-10-2012 07:47 PM
I want to add some more insulation in my attic. I have FG blown in there now. It is just above the joist's. It's higher in some spots but not much. I would like to use blown in cellulose. Is this ok? TIA...
Gary in WA 11-10-2012 11:27 PM
Check the thickness of drywall on ceiling, 1/2" at 24"oc framing = 1.6# per sq.ft. or R-49 minus the f.g. weight. 16"oc framing will take 2.2# per sq.ft. as will 5/8" drywall, or R-60; http://www.greenfiber.com/step_one_-...o_install.html
Insulation chart, Table 2; http://www.lafarge-na.com/GA-216-07_English.pdf
You will compress the f.g. with progressively more cellulose, degrading its R-value; http://www.greenbuildingadvisor.com/...fiberglass.JPG
Air seal the attic first and foremost; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
I'll help you find them; http://www.finehomebuilding.com/PDF/Free/021105092.pdf
Gary
Some
WGFA 11-12-2012 10:45 PM
Thanks for the info...
jklingel 11-13-2012 02:26 AM
The cellulose will also "seal" the blown fiberglass. Blown fiberglass is best dense packed into walls. Loose in the attic I don't think it is quite as good as cellulose; too fluffy.
fstr 11-13-2012 10:26 AM
I have a question regarding table 2 in the lined gypsum document. My interpretation is that the 1.6# per sq ft applies to wallboard. Further down in the table it specifically states ceiling board = 2.2# per sq ft. Please help me understand.
Gary in WA 11-17-2012 01:48 PM
That would be special "ceiling board", rated as stiffer/stronger for ceiling insulation-framing spacing with insulation loads only. Sorry, no links now as continuing IP problems on my end. Sorry for the late answer.
Gary
