-   Insulation (http://www.diychatroom.com/f103/)
-   -   Ceiling Sound Insulation (http://www.diychatroom.com/f103/ceiling-sound-insulation-110066/)
OhioDon 07-08-2011 02:09 PM
I am finishing my basement. This is just a "general use" basement, not a media room or anything like that. But, the television in the basement will be located directly under our master bedroom. The basement ceiling will be a drop ceiling and I intend to use tiles with decent sound absorption. The joists are 2 x 10 16" OC. I am planning to put some fiberglass insulation in the joists. I realize this will be of limited value but I think it will be better than nothing. I will probably use unfaced fiberglass with the wire rods to hold them in place. Should I use R13, R19, R30 or even R38? Does the thicker insulation make enough difference in sound to make it worth the extra money?
Leah Frances 07-08-2011 02:44 PM
No. :no:
OhioDon 07-08-2011 02:59 PM
"No" that it's not worth the cost of the higher R values or "No", it's not worth doing at all?
parts 07-09-2011 05:34 PM
Fiberglass is not the best as far as sound deadening I don't think you will see much of an improvement after R-19. The R-19 will be a lot easier to get in the bays around the wires and pipes than thicker insulation also. Roxul works better but is some nasty stuff to work with. http://www.roxul.com/home
ANGRYKOREAN 07-12-2011 06:51 AM
OhioDon, parts is absolutely correct. I've also researched this subject and the general consensus seems to be that R-19 is the 'best you can get'. You can go higher but it becomes diminishing returns.
OhioDon 08-04-2011 08:39 AM
Roxul might be around $100 more than fiberglass. Is it that much better at sound blocking?
MikeKy55 08-04-2011 08:50 AM
A bunch better. I just did mine and if the basement door is shut, you can't hear whats going on upstairs if your down or downstairs if your up.
I was very impressed with the sound deadening of Roxul.
I found Roxul user friendly too. Cut it with a regular steak knife or butcher knife. Doesn't make you itch either.
sbkim 06-11-2012 02:48 PM
Great question. Is there significant difference in sound attenuation between R13 and R30 for ceilings? Based n my cursory research, I think some insulation is better than none but can't seem to find anything that thicker insulation is that much better. Thanks
Windows on Wash 06-11-2012 08:55 PM
At R13, most of the sound is coming via the framing after that.
sbkim 06-11-2012 09:00 PM
Sorry but not sure what you mean... R19 is another reasonably priced option if that's better?
Windows on Wash 06-12-2012 08:30 AM
The vibrations that are be transmitted via the framing are the more responsible contributors for sound after the hollow cavity is insulated with either Roxul or fiberglass.
This is why staggered wall assemblies give better STC ratings.
sbkim 06-12-2012 12:57 PM
Got it thanks. Do you think R-11 is adequate for this purpose?
