Ceiling Insulation Question - Insulation - DIY Chatroom Home Improvement Forum
Old 02-07-2012, 12:57 PM   #1
Rewards Points: 131
ceiling insulation question
is it ok to use paper/foil fiberglass when insulating basement ceiling. evetually it will be cover by drywall when doing basement remodel.
s002wjh is offline   Reply With Quote
Old 02-07-2012, 01:00 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,268
Between floor and conditioned spaces, it is not what the vapor retarder layer is for.
It probably is not a huge issue if you don't have two vapor barriers sandwiched between themselves but probably should be avoided.
Old 02-07-2012, 01:16 PM   #3
Rewards Points: 131
as far as i understand foil face batt are for reflect heat back and vapor retard purpose? my basement is pretty dry, and never has any moisture issues. so should be ok to use foil face batt for basement ceiling insulation? and its ok to seal it off via drywall in the future?
i have bunch foil batt lay around in the house. so i figure i use it.
Old 02-09-2012, 11:12 PM   #4
Rewards Points: 1,092
is the basement conditioned (heated)? if so, as it sounds, then why insulate? noise? btw: any material that reflects heat (radiant barrier) needs an air space or it is ineffective.
Old 02-10-2012, 08:34 AM   #5
Rewards Points: 131
i guess eventually yes. but eventually means few years from now. but this mainly for Noise concern. i need insulate part of basement ceiling for soundproofing.
Old 02-10-2012, 04:00 PM   #6
Registered User
Rewards Points: 526
Remove the facing if there is already plywood/flooring/asphalt paper/vinyl/tile/linoleum in the floor make-up above.
Gary
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Question on Paint Sheen for Ceiling Medallion Twister Painting 9 05-18-2011 11:44 PM
Ceiling Insulation/ Sound Proofing - Waste of time? DTproject Insulation 4 04-07-2011 10:08 AM
Garage insulation question trojanman1 Building & Construction 7 09-16-2009 02:51 PM
